| Hi
I'm in the process of getting estimates for a privacy fence for our backyard. 70' - I liked this co. and their products - the build their own after specs are agreed upon. They do rec in our location to do 6x6 post vs 4x - which I agree - it can be moist in that location Hoping someone can offer me some assistance with the estimate
2nd - W/O decorative topper
1st quote = $59.97/ft
Does the construction and materials sound good quality?
Thanks for your help. |
| Forgot to add - he will set the posts in the ground not cement - I inquired about cement, he said that he doesn't like to use it, but occasionaly does, if they can't get the post far enough down - I'm not sure how far that is 2'or 3'? Thanks in advance |
- Posted by andrelaplume2 (My Page) on Thu, Nov 12, 09 at 15:13
| Its amazing how much fencing cost isn't it. We had something similar done 20 years ago in a prior home...prces have gone up! you might want those posts cemented...we had a few issues over the years. Also, check the directiion of the wind...over the years our solid 6' high fence gradually started to lean from being in the winds path. Perhaps a type of fence that lets wind flow thru is better...not sure. |
- Posted by sierraeast (My Page) on Thu, Nov 12, 09 at 17:52
| Where are you located. Great advise from A-2 concerning winds and if you have freezing temps, the holes for the posts should be well below frost line and filled with some gravel for drainage before concreting. The bottom of the post sits on top of the gravel allowing for a drainage plane. Out here, tract homes have dog eared cedar fencing consisting of 4x4's, 2x4 top/bottom rails, with dog eared cedar screwed to the frame. Even though it was almost twice as many running feet as you have, I estimated one out quite a few years ago, and it was around $7500.00 for the simple,(and butt ugly imo), dog eared fencing. Sounds reasonable to me for such a nicely detailed fence as described. Do consider the wind and it never hurts to get more than one estimate. It sounds like an awesome fence! |
| You are gettin quotes for white cedar, not Western Red Cedar. White cedar has 5-10 yr life expectancy. The wood is lower quality than you expect. Even premium white cedar is not in the same league as WRC. The prices sound fair, even for the white cedar. |
| Thank you ! |
| Eileen, Privacy fences can suffer significant wind loading, but much depends on where you are, your house versus the neighbors, landscaping, wind breaks, etc. Houses close to one another can sometimes act as wind breaks, other times they can contribute a venturi effect and actually increase wind loading. For a 6' fence I use 10' posts and go down 42" - 48". Frost depth in our area is 42". If they do use concrete, have them dig the hole, then put in a few inches of gravel, then tamp the gravel. Then set the post and add a few more inches of gravel. Then pour the concrete. As mentioned by the other posters. By doing that you end up with a concrete collar around the post instead of the post sitting in a "bowl" of concrete, the bowl can hold water. The life of the post can be extended markedly by using a collar instead of full immersion. Regardless, for a 6' tall privacy fence, due to wind loading 2' of burial won't cut it. Shallow burial depth combined with concrete can actually exacerbate frost heaving. The pricing is fair. Have you been to Rings End in Darien? I was there this morning to pick up some panel molding. They have a 6' cedar privacy fence, not sure if it'd suit your needs in terms of sturdiness or style, the fence you're getting does sound more sturdy and more decorative. Rings End panels are about $115 per 6' tall by 8' long section, and 5" square 10' cedar posts are about $40. Their fencing is not mortise/tenon though. I do need to say that I always build my own fencing, so I've never purchased fence from Rings End and because of that I've never looked at their fencing up close and personal with a critical eye. But it doesn't sound nearly as substantial as your proposed fence. Best, Mongo |
| Mongo Always a pleasure hearing you weigh in! & You were right here! could have stopped by Thanks for the info on the fencing - the co. does build their own according to cust needs/specs & I do like the M&T construction - the back of the yard where the fence - Our home has a south westerly exposure - I think the winds are more side to side yard than front to back Just sent the guy who gave the above estimate a reply: "30 to 36 inches down when dirt tamping wood posts and we use the dirt that is removed to install the post. If additional material is needed we would add sand and gravel. If we cannot get the depth we feel comfortable we would use concrete to secure the posts properly" I'll see what he says re: your rec method which seems to make more sense from a longevity standpt. |
- Posted by sierraeast (My Page) on Mon, Nov 16, 09 at 20:04
| If your frost depth is that deep, along with mongo's advise, you want to chamfer the bottom of the hole enough for the gravel as well a good bit of concrete to "belly out" in order to keep the post from heaving up in a freeze. The chamfer at the base acts as an "anchor". |
| thanks sierra |
- Posted by mrmichaeljmoore (My Page) on Tue, Nov 17, 09 at 19:51
Here is a link that might be useful: Cedar fence
| Thanks Mr Michael that was so nice of you to take time to do that! Much appreciated. |
- Posted by mrmichaeljmoore (My Page) on Tue, Nov 17, 09 at 21:46
| No problem, glad to help. This forum has helped me over the years (especially with my deck), so I try to give back when I can. Not sure if you are interested, but if you are looking to get another estimate, I can put you in contact with the guy I used. just let me know. mm |
