BBQ Minimum Clearance Built-In
Posted by ckukshtel (My Page) on
Tue, Oct 13, 09 at 16:53
I want to build a built-in BBQ up against my house. The house is one story so the overhang is approx 9 feet from the ground. The exterior walls are stucco. Is there a minimum clearance from the back of the grill to the stucco walls? Is there an issue with the overhang? I'm am looking at the 5-burner Cal Flame that puts out 97,000 BTUs.
RE: BBQ Minimum Clearance Built-In
the manufacturer should have the minimum clearances listed in teh specs. i would say at minimum you want at least 4-6" inches though, more if you can. it don't really get hot behind a grill, but no need in taking unnecessary chances.
