Is a wood a deck right up against a house a problem?
blondelle
HOW TO PHOTOGRAPH YOUR HOUSEStep Right Up: Expressing Movement on Modern Stairs
Seeing a person on a staircase changes our perception of the design
Full StoryREMODELING GUIDESThe Hidden Problems in Old Houses
Before snatching up an old home, get to know what you’re in for by understanding the potential horrors that lurk below the surface
Full StoryMOST POPULARFind the Right Glass Door for Your Patio
It’s more than just a patio door — it’s an architectural design element. Here’s help for finding the right one for your home and lifestyle
Full StoryFEEL-GOOD HOMEBack Problems? Try Putting Your Feet Up
Consider these alternatives to that one-size-doesn’t-fit-all sofa to avoid slumping and spinal stress
Full StoryECLECTIC HOMESHouzz Tour: Problem Solving on a Sloped Lot in Austin
A tricky lot and a big oak tree make building a family’s new home a Texas-size adventure
Full StoryTRIMTrim Color Tips: Get Your White Trim Right
Set off wood tones, highlight architectural features, go minimalist ... white trim is anything but standard when you know how to use it
Full StoryBUDGETING YOUR PROJECTDesign Workshop: Is a Phased Construction Project Right for You?
Breaking up your remodel or custom home project has benefits and disadvantages. See if it’s right for you
Full StoryLANDSCAPE DESIGNHow to Pick the Right Paving and Decking Material
Once you’ve got the walls or fences of your garden figured out, it’s time to consider the ground surface or floors
Full StoryHOUSEKEEPING10 Problems Your House May Be Trying to Show You
Ignore some of these signs and you may end up with major issues. We tell you which are normal and which are cause for concern
Full StoryDECORATING GUIDESSize Up the Right Area Rug for Your Room
The size of a rug can make an important difference to the feel of a room. Here are some tips to help you make the right choice
Full StoryMore Discussions
marcinde
millworkman
Shorewood Decks, Patios & Outdoor Enclosures · Boise Decks, Patios & Outdoor Enclosures · Garden City Decks, Patios & Outdoor Enclosures · Novi Decks, Patios & Outdoor Enclosures · Rosemont Decks, Patios & Outdoor Enclosures · Somerville Decks, Patios & Outdoor Enclosures · Highland Decks, Patios & Outdoor Enclosures · Lake Morton-Berrydale Home Builders · Beaufort Flooring Contractors · Brooklyn Park Flooring Contractors · Lexington Flooring Contractors · Mission Viejo Flooring Contractors · West Linn Flooring Contractors · Manassas Siding & Exteriors · Waterford Siding & Exteriorshilltop_gw
deckman22
Builder-Bob
