Mon, Sep 17, 12 at 11:29
| Which is better to use? I have a redwood deck that is in serious need of refinishing. I've decided to use a semi-transparent on the floor and top rails, but for the spindles and posts I'm going to either use a solid color stain or paint them. Which is the better to use? We live in Colorado and half of deck is in full sun. It takes a beating. |
- Posted by fnmroberts (My Page) on Thu, Sep 20, 12 at 19:14
| Oil based stain. You'll not have peeling. |
- Posted by Jumpilotmdm (My Page) on Sun, Sep 23, 12 at 12:30
| Be careful. Oil based stains have changed. Read the label and follow the directions. Do not ignore the recommendations or you will invite a mess. Solid color stain that is oil can probably be applied with no primer thereby eliminating a step, whereas a solid acrylic will probably need a primer. However, the acrylic will hold up in the sun better over time, providing it is properly applied. Paint will have a heavier film build to it and maybe even some sheen, like a satin? Personally I'd be happier with the look of stain, which is flat. |
