Solid Color Stain or Paint on deck?
Posted by christyinco (My Page) on
Mon, Sep 17, 12 at 11:29
Which is better to use? I have a redwood deck that is in serious need of refinishing. I've decided to use a semi-transparent on the floor and top rails, but for the spindles and posts I'm going to either use a solid color stain or paint them. Which is the better to use? We live in Colorado and half of deck is in full sun. It takes a beating.
RE: Solid Color Stain or Paint on deck?
Oil based stain. You'll not have peeling.
Be careful. Oil based stains have changed. Read the label and follow the directions. Do not ignore the recommendations or you will invite a mess.
Solid color stain that is oil can probably be applied with no primer thereby eliminating a step, whereas a solid acrylic will probably need a primer. However, the acrylic will hold up in the sun better over time, providing it is properly applied.
Paint will have a heavier film build to it and maybe even some sheen, like a satin? Personally I'd be happier with the look of stain, which is flat.
