JOIN NOW LOG IN
Anyone tried TENDURA? No search results!
phaze-3
(gw:phaze-3) on
Thu, Sep 14, 06 at 8:21
www.tendura.com -- Seems like a T&G version of Trex, recycled plastic bags and sawdust and such. A buck more a foot than mahogany, but should be maintenance free. I got a sample from the website and it's only 7/8" thick, but has a textured surface and the color goes all the way through.
Has anyone used, or heard anything about it?
RE: Anyone tried TENDURA? No search results!
I used Tendura for my covered porch over three years ago and I'm very happy with it. Anyone who has come over and seen it absolutely loves it and wants to know what it is! I live in western NY(hot summers, cold snowy winters)and have had no problems with it! Unless they have changed it since I bought it, Tendura comes primed and then you would need to paint it. Hope this helps.
Pat
  • Posted by
    phaze-3
    (gw:phaze-3) on
    Thu, Sep 14, 06 at 13:24
Did you use a one-coat porch paint? Any slippery issues? If seems to have a good textured surface already. I'm in NJ, so weather is similar, if a bit less harsh in the winter. Thanks.
Please allow me to provide a little more information concerning TenduraPlank. TenduraPlank is comprised of 40% top grade polypropolyne plastic (plastic bags, etc. are not used in the manufacturing of the product) and 60% wood fiber. The wood fiber is a sawdust and wood flour composition. Wood chips and chunks are not used in the process. This allows the wood fiber to be encapsulated in the plastic. TenduraPlank has a slip resistance surface and comes in two different formats. TenduraPlank Classic, which can be painted and TenduraPlank Weathered Gray, which cannot be painted. Tendura Classic should be painted within 90 days of installation using two coats of Latex or Oil Base porch paint. The gray product is designed to resemble a weathered wood porch. It will not be a solid color as you would find on a painted porch but will have a blended color variation across the porch instead. Please visit our website for more information.
Tony Galloway
Operations Manager
Tendura
Here is a link that might be useful: Tendura Porch Flooring
  • Posted by
    phaze-3
    (gw:phaze-3) on
    Thu, Sep 14, 06 at 14:59
Thanks, Tony. I've been scouring any forums I can find for Tendura info. One concern that pops up again and again is heat and warping.
My porch is covered, but does face south. Because this is an old house with odd-ball framing, the porch joists are also the basement's ceiling joists (some of them) - no underlayment beneath the current T&G porch boards.
Would my basement would serve as enough of a heat sink to keep the Tendura cool?
Here is a link that might be useful: Porch photo
Yo GW, you might want to have a read over to the tendura instalation instrustions, Ol Tony would send you a copy Im sure. J
