How many carbide saw blades for Ipe
madducks (
Wed, Sep 2, 09 at 0:55
About how many carbide tip saw blades will you wear out cutting Ipe - For example: per 100 square feet, will need about 2 blades for the chop saw?
Thanks. |
RE: How many carbide saw blades for Ipe
| I'm sure John and others can give you an idea about how many blades, I just wanted to mention that carbide blades can be re-sharpened although it's typically hard to find a sharpener that is set up for it. Might be worth looking in your area to see if anyone does it. A good sharpener can make them as good, if not better than new. |
| A bit off topic, but any of you resharpen drill bits and utility knife blades? If I have it nearby, a quick pass or two on a handheld knife sharpener is quicker than switching it out. |
| Hi Homebound, A drywall hanger friend back in the old days had a small sharpening stone hanging off of his bags. He would hit his knife blade on it now and then and rarely had to switch out blades on a project. I use a drill doctor for sharpening bits, but you can only sharpen down to about an 1/8" drill bit. Any smaller you have to do by hand. I typically just buy handfuls of the smaller bits and pitch them when they dull. |
| It all depends on the quality of the blade. I use Jesada Tools blades. For a project of 100 sq ft those blades will just about start to warm up. J. |
| I put down ~1,000 sf and used 1 Dewalt blade with no issues. Drill bits seem to wear vs the blades |
| Jesada is still around? Is it still run by Carlo or his children? |
