| Hello! I just installed a new PT wood perimeter fence and would like to treat it in a manner that will help keep it looking good for along time while minimizing maintenance. The fence is part of a larger pool project. Right now I am considering whether to use Cabot SPF 48 Sunray or thier Australian Timber Oil. Any recommendations? Also, how long should I wait before applying the treatment? I read Cabot SFP 48 can be applied right away. Thanks in advance! |
| Hi, I used Cabot's SPF-48 Sunray on an Ipe deck about 6 years ago and it peeled badly. It is a water based product that does not sink into wood. Having said that, it held up well on the vertical surfaces, so it would probably do well on a fence. If there are any horizontal surfaces, e.g. tops of fence panels, and you live in a cold zone with freeze/thaw cycles, it is likely to peel off in those areas. In that case the Australian Timber Oil would be a better bet, although you would likely have to reapply sooner than with the SPF. Cabot's recommends cleaning wood prior to staining. Their cleaner is bleach based. You might prefer a sodium percarbonate based cleaner instead. This site: http://www.woodrich-brand.com/ has a good video on how to clean and stain a fence as well as their own sodium percarbonate based cleaner. I can't speak to waiting to apply stain on PT lumber, but most experts here say don't wait. You could ask Cabot what they recommend. Good luck, |
| thanks marty. im also going to look into the one time product based on the majority of the reviews on this site. |
| you want your PT wood to dry out unless it was KIL DRIED. i would say at least 3 months to dry. i like OLYMPIC MAXIMUM stain in rosewood from lowes. cabots i use on my IPE wood and iut lasts about 1 year and you have to take it all off to re-stain your ipe. for PT wood i really like the olympic maximum stain . |
