Aluminum railing side mounting brackets
Posted by zver11 (My Page) on
Mon, Aug 8, 11 at 17:26
I am using Aluminum railing (Gilpin) on my deck. Most posts will be surface mounted. A few need to be side mounted. Gilpin makes a non-flanged long post(all posts 2.5" sq). They, however, do not make a side mounting bracket. Mounting the posts with a simple thru bolt is questionable since it would tend to collapse the hollow post and weaken it in the critical outward pushing direction.
1) Are 2.5" posts reasonably standard--will a bracket from any railing manufacturer work?
2) The only other manufacturer I found lists 2.5" brackets at $37/post--just for brackets! Is there any reason I can not make my own brackets by bending heavy sheet aluminum? I would need to prime and paint. Finish would not be powder coated, but otherwise should match reasonably(black is not a hard color to match)
