- Posted by salmon_slayer (My Page) on Sun, Jul 5, 09 at 19:46
| great start. We are almost done ourselves with a DIY deck. The pros on here are awesome and will point out issues and make recommendations. Hope you estimate better than me. I was hoping for $13, figured $15 and spent $20 and took waaayyy longer than I thought. It grew on me... I have to keep reminding myself: its only a deck, its only a deck. A contractor friend stopped by to "supervise" early on. He gave me a rough estimate that I thought was ridiculous. After spending nights, every weekend and taking time off from work, I now understand. My bet is you will too in a week or two. Keep the pictures coming! |
- Posted by john_hyatt (My Page) on Sun, Jul 5, 09 at 20:18
| Nice start Weedster,one thing the area will dry out faster with the tarp off and some big fans from homecheppo going full blast on them. J. |
- Posted by weedyacres (My Page) on Mon, Jul 6, 09 at 13:23
| Well, at 6am today we pulled off the big tarp and all the little tarps to survey the damage. Two of the holes right by the corner of the house had water in the bottom, which we Shop-vac'd out. The rest were dry, thankfully. The sun, breeze, and rising temperatures are drying the dirt out pretty well. Inspector Adam showed up just before 9 and blessed our holes. We shoveled some gravel into the bottom of each and then the concrete showed up at 11. Five yards down to the last drop. Some of the forms egged out slightly (didn't pack the dirt tightly enough?), and a few were a bit off level (or maybe I didn't cut them exactly straight). But for the most part they looked good to this DIY eye. Cost so far: $1206 for sonotubes, gravel, concrete & child labor. Now...time for lunch! |
- Posted by weedyacres (My Page) on Tue, Jul 7, 09 at 13:39
- Posted by john_hyatt (My Page) on Tue, Jul 7, 09 at 17:39
| Way to go Girl!! I use a skill worm drive, finish it off with a resepo saw. J. |
- Posted by weedyacres (My Page) on Tue, Jul 7, 09 at 22:12
| Looks great so far. I had a similar experience once I dug my holes. The rains come and washed my holes in . . . dug them out . . . rain. I didn't use full depth sonotubes because those things are expensive. I just used them to get the foundation out of the ground. Your way was probably easier. It looks like you are building a free standing deck, am I correct? If so then I believe you should have diagonal bracing in both directions. I have a structural engineer friend that was adamant about diagonal bracing even if I was attaching it to the house. I probably overkilled on the bracing and braced in both direction at every post. You might be able to get away with every other bay, but hopefully some of the pros will have some thoughts. Keep up the good work, post lots of pics, and ask lots of questions. Riles |
- Posted by salmon_slayer (My Page) on Wed, Jul 8, 09 at 9:35
| be mighty careful how your running those 6x6's through your table saw. A small bind or twist while your running it though that way is going to hurt you. Part of the learning curve you do not want to go through. Also - consider rough cutting the larger pieces with a circular saw and /or recipricating saw, then take the smaller piece through the table saw. Your asking for problems with those larger pieces cutting them that way. steve |
- Posted by weedyacres (My Page) on Wed, Jul 8, 09 at 21:35
- Posted by salmon_slayer (My Page) on Thu, Jul 9, 09 at 10:16
| I was "encouraged" to put a waterproof material over all the lumber that was "sistered" to prevent water from sitting there and rotting the wood. That was also where my previous deck went bad first. I was anal so I also put it on top of my posts as well as it also act as a barrior between the PT and brackets. It seemed like cheap insurance. Available at HD/Lowes and local deck store. Defer to the pros to comment if I wasted my $$ or its worthwhile. Keep the pics coming |
| As far as the cross-bracing goes I didn't realize this deck was so low to the ground. Mine was about 4' off the ground. I think I would still brack the outer posts. Just curious how far the joists are spanning, some look like they are spanning quite far? Hopefully it isn't a problem as I am no expert. Riles |
- Posted by john_hyatt (My Page) on Thu, Jul 9, 09 at 17:58
| I saw that too Riles, They said there was some blocking going in. The entire aproach seems strange to me in a lot of ways. I am thinking those Folks will learn a lot on completion. J. |
- Posted by weedyacres (My Page) on Thu, Jul 9, 09 at 21:49
- Posted by john_hyatt (My Page) on Fri, Jul 10, 09 at 7:22
| I always pick up East Teak material on the dock that is the trucking co dosent deliver it. Saves a lot of time plus I can just work off the tandum and only move the lumber one time. When I build a free standing structure over the deck I use.40 pt posts set in the ground with creet then wrap them in say cedar like your using after the decking is installed. With a 2x12 frame it is possible for the joists system/made up beams to react to the sun . The biger the lumber the more movement. If you notices any big humps either on the eyeball or while streaching a string investing in a makita power planer would be a good idea. J. |
| Your project is looking great. I didn't mean to alarm you about the joist spans. I think the pictures skew reality because I went back and found your framing plan and it looks like you are using 2x10's (not sure if that is 24"oc or 16"oc) and your spanning 12' (the pics make them look longer). The charts I have show max. 13' for 24"oc and 15' for 16"oc. I know the pros opinions on those charts, but it looks like you are OK assuming your anticipated loads are not greater than the assumed 40psf-live, 10psf-dead. Keep up the good work, your project is looking great! Riles |
- Posted by weedyacres (My Page) on Fri, Jul 10, 09 at 21:25
- Posted by salmon_slayer (My Page) on Fri, Jul 10, 09 at 22:59
| LOL. "It's only a deck" Pretty soon it's "only another hundred" Keep the pics coming. How are you going to cover the sides and the piers? Steve
- Posted by weedyacres (My Page) on Sat, Jul 11, 09 at 8:18
| Oops, meant to respond to John and Riles. John: We'll give the nailing plane a good eyeball and plane off any high spots on the joists. Great idea! I also like the idea of disguising those ugly posts with cedar. Riles: Yes, the joists are 2x10 and the tables do indeed say 15 feet span is ok. Our deck was engineered for 55 psf total load. But those things were awfully bouncy before I put the blocking in. They're much more stable now. I definitely agree with Jon Mon there. |
- Posted by john_hyatt (My Page) on Sat, Jul 11, 09 at 9:45
| Actually Weed,I was talking about your cover posts ya know the ones sticking up in the air. I put in handrail posts like that but your asking a lot from the conection you have them placed in. Its also the weak point in your project in two ways. 1 all the weight is going to be on the bolts, not good,wr cedar is just too soft for that I suggest pier pads under them with pt posts going up to the cedar from underneith secured in a tight nature. 2 WR cedar will rot quickley confined with pt framing like you have done, thats why I use pt posts then wrapp them in cedar. Water will get in around them and bang bang you will have major rot starting with the first rain and be a real problem in no more than 2 years. Not a whole lot to do about it now,mabey copper green poured in between the the framing and the cedar posts or anyother kind of mildiside, even motor oil might help. You seem to be up on tools/know how , and have a good helper, so I will run this by you>> Copper flat stock installed around all the cedar posts with copper nails Shaped with a block and a hammer so it runs up the posts 4'' or so and down to the framing another 4''. Copper stops organic growth so the more water,the more it leaches,the more protection << The span charts you guys keep going to were never ment for Decks,they are maxed out to the point of faliure in other words the most you can do, they are used for house framing and even there Framers will insatall blocking or strongbacks. J. |
- Posted by weedyacres (My Page) on Sun, Jul 12, 09 at 8:08
- Posted by john_hyatt (My Page) on Sun, Jul 12, 09 at 10:16
| Pier pads,footings like you have pored already. Over here we have Dolice concret Co who make blocks as well like cap blocks 4 x8 x16'' solid creet those would work. The homecheepo block you found would work if you turned it upside down or just poor some more. Fasten a pt plate to them install the posts. Another area that might get a little tricky,Wind,diagonal stress. Posts set in creet provide a lot of protection from this. With your set up all the stress is going directley to your deck frame, not good. At this point addding diagonal bracing to your posts would be complex in fact I cant figure out how to do it with any lasting benefit. I am not knowing how your going to finish out the Cover but one thing you could do is add small wing walls to all four corners. These could be say...three/four ft wide construsted with 3/4'' cdx plywood bordered all around with 2x material then covered with sidding or some of that 3/4'' garapa. These walls are fastened to the posts,the decking and the framing up above. After install they will provide very ridged side stress protection so your design flaw will be solved. Keep the Garapa covered and off the dirt while its waiting to go down. After all the care and work on the cedar posts get the finish on them as soon as possible even then they will crack up thats just the nature of WR cedar timbers. You are looking for Cross Ventalation, air moving in and out under your deck. The gap inbetween the decking will not provide this so just go with the normal 1/8'' or so. If you go with solid skirting place screened foundation vents in that skirting these can be made up on site with the skirting material and are placed so you get Cross Ventalation...air in..air out. I have no idea what your talking about with the spacers. Overhanging the decking is not a good idea for a lot of reasons. Install end grain trim. Extend the decking over the frame an inch or so then snap a line,cut the decking to that line. The line will provide a straight surface to attach the trim and also make up for any uneven areas in the deck frame. Say your using 3/4'' skirting,rip the garapa to 1 1/2 '' x what ever leangth your good working with, I put a router detail on, install the trim with TightBond 111 and ss screws all around the outside of your project. Doing this will seal the ends of the decking,tie them all together and provide a 3/4'' reveal to bump your skirting to. It also is a Class Act really gives your job a cool finished touch looks like the Big Boys did it. The vents and endgrain trim can be seen on my site, and youall owe me Big Time!!! I have just saved you from Major bad dream problems. JonMon |
- Posted by weedyacres (My Page) on Sun, Jul 12, 09 at 21:08
- Posted by john_hyatt (My Page) on Sun, Jul 12, 09 at 23:28
| Skirting to the rim joist is the only way to fasten it, still unclear what the spacer thing is all about. I dont see any diagonal braces in that plan, I see cross members conected up a ways, but your idea of diagonal and mine could be different. The intire idea of only 3'' of movement until the thing hits the house is in complete flawed mode. If you have that much movement at any given time that thing is coming down and taking your deck frame with it. Your cover plan is total top heavey with no positive conection to the ground, or really anything else. It would be possible to install real diagonal braces on all four coners of the cover, that is say 4/5' 6x6 fastened at a 45 to the posts and the upper framing. The joint conections should be very secure. That might spoil the look your going for but it would give the little Lady places to hang stuff like they love to do. I hate those things cause I alwyas knock my head against them. Another plan would be to run 4'' glav steel L chanell creeted in down below,runing up the side of the important 6x6s and fastened to them this could be done in conjunction with the added piers. Hang in there Bro. J. |
| So....are you happy with the delivery from ABS? I am thinking of ordering my garapa from them if they come in with a good price. |
- Posted by weedyacres (My Page) on Mon, Jul 13, 09 at 19:56
- Posted by weedyacres (My Page) on Tue, Jul 14, 09 at 23:03
- Posted by john_hyatt (My Page) on Wed, Jul 15, 09 at 7:57
| Little trick>>> 5/32'' black bit, a garapa spacer with a hole in the middle chucked into your drill to the right leangth showing on the bit so you dont get into the pt frame.<<<< So you have the bit going through the spacer into your chuck set at the right debth. Its almost impossible to break the bit used in the spirt of a sound mind. J. |
| Do you think the smartbit tool would help reduce bit breakage? I was thinking of getting a couple of those. |
- Posted by salmon_slayer (My Page) on Wed, Jul 15, 09 at 9:49
| the smartbits worked ok for me but we still went though a few bits. (No where near $300 though) I started off with 2 bits ($15 each) and two packages of replacement bits ($12-$15 - 5 bits in a package) The learning curve had every helper break 2 or 3 bits before we figured out you had to go staight in and back out - no forgiveness/sloppiness and do not stop in the middle. We had to use longer bits when drilling from Ipe to Ipe (vs Ipe to PT). That got fun when the oily wood heated up - it "pops" Not sure about Garape but if it does it - you will know. The smartbits are designed so they do not "clog" up as fast as a regular bit. |
- Posted by weedyacres (My Page) on Wed, Jul 15, 09 at 10:11
- Posted by john_hyatt (My Page) on Wed, Jul 15, 09 at 20:21
| Weed Man,I dident notice your were pluging thats makes a pinto out of a paint. I use a forster bit first then the pilot drill. I am not understanding the alum over the copper, But Dude!!!! you are a hard Worker. When that thing is done the JonMon would be proud taking the Harley out there and buying you a Tecate. |
- Posted by salmon_slayer (My Page) on Wed, Jul 15, 09 at 20:53
| Wow, I missed that too (plugs). That's a lot of plugs and a lot of sanding! It will be fantastic when done. You said a week? John, wont the alum turn to dust next to the PT? |
- Posted by john_hyatt (My Page) on Wed, Jul 15, 09 at 21:59
| Its not regarded as the best kind of install Sam,alum against acq, but most likeley its micropro that wont give out specks at all. In Fact mcq ground contact,if you dig in the fine print, is ground contact,but that dosent mean under the ground so you cant cover it with....Like....Dirt!!! Homecheppo is selling .15 mcq keep in mind .40 was ground contact and they were selling .25 with acq. They forget to tell this to the Wallets of course. So what the Helllll it really wont make any diferance. The Mans real issue is diagonal but same kinda deal, Go on with it Dude. J. |
- Posted by weedyacres (My Page) on Thu, Jul 16, 09 at 8:54
| No fear on the flashing. The inside is copper and the outside is a plastic of some kind, not aluminum. The stuff is actually called deck flashing, recommended to protect ACQ from the hardware. I do need to move the flashing down a tad so that I can still attach the lower bannister rail to the post without the screws hitting the copper. "Making a pinto from a paint"??? I don't speak Oklahoman, is that a good thing or a waste of time? :-) The Forstner bit would certainly do better digging into the wood than a countersink...might be worth a try. You really drill twice, then drive? There goes my timeline again. ;-p Yeah, salmon, a week. That was the original plan/hope: to get the thing decked by the end of last week since we had 3 full-timers and a couple kids-on-call. We'd still have the pergola, railings and stairs, but the bulk would be done. The late-arriving decking put a wrench into that plan, though getting all of it in in 2 days even with the full crew might have been wishful thinking. |
- Posted by john_hyatt (My Page) on Thu, Jul 16, 09 at 11:25
| A horse of a different color. The forstner bit is a sure thing and a lot cleaner cut. J. |
- Posted by weedyacres (My Page) on Thu, Jul 16, 09 at 22:25
- Posted by salmon_slayer (My Page) on Thu, Jul 16, 09 at 23:01
| Given the amount of plugs your going to need, you might give your supplier a call. I bought mine from East Teak and they were great. I think they were about 15 cents a piece. well worth the time. |
- Posted by thinkstoomuch (My Page) on Fri, Jul 17, 09 at 8:39
| Ditto on East Teak plugs. I am working with their Ipe plugs right now and am very pleased........... |
- Posted by john_hyatt (My Page) on Fri, Jul 17, 09 at 14:02
| Im not real sure ET sells garapa plugs,could be. Cuting grapa on the drill press is not as hard as ipe but it still puts out a lot of smoke,I am thinking there is a lady poster,so Mam be sure and run a big fan into the work while your cuting them. Also give the plug cutter a break every now and then and give it a cleaning. There are two ways to release the plugs one involves the table saw and the other is just poping them out with a screw driver I have found the screwdriver works best for me. No matter how cearful I am the table saw rips up a lot of them. Counter sink the plug hole a good 1/4'' I usually just go the debth of the forster bit. JonMon |
| weedy, I have a 1000 Garapa plugs left over from my project. Email me and we can find a way to get them to you. marcus4atcomcastdotnet |
- Posted by weedyacres (My Page) on Fri, Jul 17, 09 at 22:06
| ABS offered me plugs, but at 15 cents apiece (for a tiny piece of wood???) that was going to be over $400, and I figured the wood is free and my time is cheap, so we're doing our own. I can cut 200+ plugs in an hour, so my payback is at least $30/hr, which tipped the scales to DIY on those. (Marcus, I have emailed you.) John, you're right, after about a half dozen plugs the drill press starts smoking, so we've got a little container of water that we dip the drill bit in to keep it cool. And we're going the screwdriver route as well. We got a hefty rain last night, so had to let the deck dry out until mid-afternoon. Then three hours of plugging and our holes are closed up! Plugging is simple enough, but awfully tedious. I had a small bin of light, one of medium, and one of dark plugs, picked the closest one to the board I was doing, aligned the grain, and popped it in with some Titebond III. Tomorrow we start on the "grill deck" (the one in front of the turret). |
- Posted by weedyacres (My Page) on Sat, Jul 18, 09 at 23:33
| Well, got a good start on the grill deck today. It took a bit of time to figure out where to start the first board, add blocking for the trim piece, cut/align the trim piece and do all the cutting around the pergola posts. But at least the drilling and screwing goes forth steadily without breaking bits. Right now the trim piece is just laid over the decking boards. Obviously we still need to cut them off. We tried an experiment with the plugs: making the plugs from a piece of the same board so the color match is good. How OCD is that!! Don't know if we'll keep it up, but it's an interesting experiment. One new issue with the plugs, though. They're not snug. Either the plug cutter's cutting small or the forstner bit's cutting too big (both are 3/8"). The plugs just slip in, no pounding required. Do we need to step up the size of the plugs? |
- Posted by john_hyatt (My Page) on Sun, Jul 19, 09 at 9:06
| It will probley work with enough glue but the TB111 will leave a little dark circle,no big deal with the finish on. Using a tapered plug cutter would help. www.leevalley.com Pretty soon youall are going to know all the little tricks. J. |
- Posted by weedyacres (My Page) on Mon, Jul 20, 09 at 22:42
- Posted by salmon_slayer (My Page) on Tue, Jul 21, 09 at 9:37
| good picture angle. It looks like you are staining the pergola. If yes, staining it before it goes up is a smart idea. Much easier to do before putting it up. We are making very slow progress completing our Ipe deck. We got distracted with having to install a bunch of patio doors, only being able to get to it on weekends isn't helping and someone got into my garage and stole a lot of tools. (I had brought them home from our vacation house because I was concerned about leaving them there - go figure) Steve |
- Posted by weedyacres (My Page) on Tue, Jul 21, 09 at 21:32
| Man you really should have gone with T&G garapa ;-) |
- Posted by john_hyatt (My Page) on Wed, Jul 22, 09 at 22:23
| Like I said youall are some hard workers,the thing looks good to me. I am not understanding the little posts coming up but Im sure I will. JonMon |
- Posted by weedyacres (My Page) on Thu, Jul 23, 09 at 21:36
| Rain, rain, go away. The garden loves it, but it doesn't do much for deck building. Two days of nothing, and tomorrow we've got "stuff." Have to do some catch-up on Saturday. The inspector did stop by to check out our framing and pronounced it "overbuilt." That's what we wanted to hear. We've been trying to decide whether or not to put diagonal bracing in underneath since it's free-standing. The AF&PA's Design for Code Acceptance calls for it on all decks over 2 feet tall. Ours is on the borderline (parts over 2 feet, parts under, tallest post only about 18") and there's not enough clearance for the 2-foot-to-2-foot diagonal the DCA prescribes. I asked the inspector and he said "not required." So I think we're going to skip it. While moaning at the weather, I did do some calculations and design on the stairs, and bought the materials for them. Here's the plan (feedback welcome): One set of stairs is about 4' wide/5 steps, one about 8' wide/6 steps, and one will be box stairs instead of stringers. 3 short steps from 2x6s. Other thoughts/ideas? |
| I'm with you on the pre-cut stringers. I cut my own and they were a pain in the neck. They turned out good, but if I had to do it again I would of used the pre-cut ones. On the risers I also mitered the corners, but if I were doing it again I would of just ran the one in front long and butted the side risers up behind. The mitering was more work and the way the wood moves outside it is tough to keep these miters tight. It could just be my DIY woodworking skills. Riles |
- Posted by weedyacres (My Page) on Tue, Jul 28, 09 at 20:04
- Posted by john_hyatt (My Page) on Tue, Jul 28, 09 at 21:33
| Mrs Weed Mam, I am not understanding all that Creet for such a small stairway. Unless you all are planing something extra to land on that slab it is way to the max overkill. Compaired to what you have already done cuting stairbucks is easy. No way would I use the homecheppo pre cut one chance in a bunch they are going to give you what you need.Just post the rise and run and the JonMon will give you the cut. I have respect for any Rider that goes it for 3 weeks,its not the way I do it with the trailor and all but what the hay. See if He wants to come on over Me and Susan will put him and the Dad up for the night, then take him on over to the Freedom Harley shop to look at a real Motorcycle, Just Kidding Girl,phone and map are on my site. |
- Posted by weedyacres (My Page) on Thu, Jul 30, 09 at 15:26
- Posted by john_hyatt (My Page) on Thu, Jul 30, 09 at 21:34
| NO problem with the plugs Allison,they will all blend together. Fastening the skirting with 2 1/2'' trim nails is all good the length is so short you should be able to tap them into place. Good Idea to use construstion adhesive behind them. Provide cross ventalation in the skirting very important. Keep the shorts stacked up,dry, and under cover if your using them for skirting. Strong Women, way to go!! Hows He doing on the bike with all the rain. J. |
- Posted by weedyacres (My Page) on Fri, Jul 31, 09 at 21:40
- Posted by john_hyatt (My Page) on Fri, Jul 31, 09 at 21:55
| Stairs look good to me,garapa on the treads will study up any shake in them now. I have been using the liquid nail heavy dudy stuff for adhesive because the green mafia outlawed the 490 if there is still some on the shelves buy it. The skirting should just bump up to the border overhang just fine. J. |
- Posted by salmon_slayer (My Page) on Sat, Aug 1, 09 at 23:40
| John, I put in blocking, was that overkill or just needed for the posts? |
- Posted by thinkstoomuch (My Page) on Sun, Aug 2, 09 at 6:30
| John, Steve, etc, Regarding the stringers above........ Is the 2x bolted to the concrete pad necessary/recommended, or can the stringers simply rest on the concrete pad? How do you avoid rot from moisture when dealing with stringers connecting to a concrete pad? Is the fact that the wood is pressure treated enough? Thanks, Kim |
- Posted by john_hyatt (My Page) on Sun, Aug 2, 09 at 8:57
| Blocking the stairbucks will stiffen them up and provide backing for the skirting if its going up and down. And of course its nessecary to place the rail posts. It would be a little tricky to fasten the stairbucks directley to the slab and not near as good as the pt plate. Far as rot goes most of us are using micro pro pt lumber now, this stuff is as bad as it can get far as protecting the wood, the worst yet after the fall of cca. I myself have been using motor oil on the pt plates that go in the ground with my Jobs while looking around for something else. Its not as easy for me as it was for the Weed's to keep the pt lumber out of the ground most of the time I cant use the zmax metal post brackets just because of the way I frame the decks. Contact with a slab is not as bad as in the dirt but like I said I am looking for a paint on that will brace up the really poor pt lumber we are using now in the more important areas. |
| re: skirting fwiw...I went with vertical skirting on my steps cuz it is easier to see the step with the contrasting alignment. Easy to do with miter saw and finish nailer. |
- Posted by john_hyatt (My Page) on Sun, Aug 2, 09 at 22:58
| Pretty sure I just found the product I was looking for> Cuprinel<. Now why dont they treat framing lumber this way? Never mind I know it makes too much sence. J. |
| John, Cuprinol No 10 Green is what I have been using. Found a gallon can on sale at Menards for my deck. Works great for cleaning my brush after coating posts to be buried with non-fiber foundation coating, too. |
- Posted by weedyacres (My Page) on Wed, Aug 5, 09 at 13:30
- Posted by john_hyatt (My Page) on Thu, Aug 6, 09 at 6:25
| You might want to put 4 little blocks under the box step landing on the garapa its always good to have air and light under a set up like that. Taking down the plugs goes pretty fast for me with 60 grit/5'' makita orbital. J. |
- Posted by brooklyndecks (My Page) on Thu, Aug 6, 09 at 18:09
| Weedy, Real nice deck. I've enjoyed following the progress. A multimaster will work well on those plugs...I wish I had one. Personally, I use an extremely sharp chisel, and chip the plugs close to the deck. Then I sand the remains with my 5" Ridgid random orbital sander with 50 grit discs (the black ones that they sell at Lowes). The Ridgid is a great sander, and that 50 grit is very aggressive. Don't spot sand the plugs, as you'll see it after you put on the sealer. Sand the entire deck. I look forward to seeing the finished deck. steve |
- Posted by weedyacres (My Page) on Fri, Aug 7, 09 at 9:10
| John: How high do I need to raise the box? Is 1/8" or 1/4" enough? I cut the box so it splits the rise exactly in half, so I'd like to avoid having to plane everything down again if possible. Alternatively, would it be sufficient venting if I (I know this is unconventional) drilled a few holes in the decking that will be covered by the steps? All I had laying around was 80 grit, and my ROS cut down two at a time in about 30 seconds without too much effort. I'll try the multimaster and compare. I'm worried that if I chisel them I'd sometimes take off too much. |
| I came here WAY late. Please someone explain Garapa for me. Wikipedia thinks it is a juice from sugar cane. I will be building a small deck in my back yard, that is why I looked here in the first place. I LOVE what you did! It's awesome. But way bigger than I could ever put on my little lot. :) Moni |
- Posted by john_hyatt (My Page) on Fri, Aug 7, 09 at 10:01
| 1/4'' little spacers would do it Allison you can put them on with tightbond 111 and a trim nailier. I never spent the time to get a chisel sharp enough to do that either but really no need the random orbital works fast enough for me. Steve is a class trim Carpenter he has all that stuff. Okla google up Garapa Decking,you will get a full screen. |
- Posted by brooklyndecks (My Page) on Fri, Aug 7, 09 at 21:05
| John, It looks like her plugs are 1/2"+ proud of the deck surface. She can't sand them. Those holes in the bottom of the RO sander will grab those plugs, and break them every which way. Chiseling is the way to go, or a mutlimaster...or a small japanese style saw. steve |
- Posted by weedyacres (My Page) on Fri, Aug 7, 09 at 21:05
- Posted by salmon_slayer (My Page) on Fri, Aug 7, 09 at 21:42
| well that was an interesting comment...... "P.S. John, don't be blowing my cover. :-)"
- Posted by john_hyatt (My Page) on Sat, Aug 8, 09 at 6:59
| Who Me??? Never. The endgrain trim works for me. I go about the treads a little different by running the kick plate or the riser cover after the treads are in but yours looks good as well. I know you probley will but be sure and add blocking all around the stair posts with construstion adhesive. J. |
- Posted by weedyacres (My Page) on Wed, Aug 12, 09 at 18:23
- Posted by salmon_slayer (My Page) on Wed, Aug 12, 09 at 21:23
| I am impressed with how far your getting doing this in your "spare" time. The photo showing the graying was great. When do we get some stain?? |
- Posted by john_hyatt (My Page) on Thu, Aug 13, 09 at 7:59
| Stairs are looking goood. Not to worry about the weathering garapa a light oxalic wash will bring it right back with a little scrub work done by the child labor. J. |
- Posted by weedyacres (My Page) on Thu, Aug 20, 09 at 22:10
| Funny you should mention squeaky. I just finished screwing in my garapa decking and I found the same thing. They seemed ok when I first put them in. Now they are squeaky. Is this going to be an on-going problem since I didn't use any glue? Will tightening them up one time do the trick? Never had this problem with nails. |
- Posted by weedyacres (My Page) on Sun, Aug 23, 09 at 20:10
- Posted by john_hyatt (My Page) on Sun, Aug 23, 09 at 21:34
| I am thinking you all are using the ballusters that fasten from the outside. One way to solve the height thing..install a 1'' strip on the top rail then a cap rail laying flat on the strip. Have a safe and good trip, garapa/twp shorts on the way mon or tues. J. |
- Posted by weedyacres (My Page) on Sun, Jun 20, 10 at 17:21
| Boy, I have to say that this is pretty irritating that GW lost the final month's worth of posts on this project. |
- Posted by john_hyatt (My Page) on Sun, Jun 20, 10 at 22:32
| O Man!!! thats just not right. It would be good to see that. Hope the Bike is runing good and you keep the paint up and the rubber down. JonMon |
| Wow, i just got through reading this whole thread, and what a let down not to see the final result! I'm looking into Garapa for my deck and would love to know the weedy's impressions after living with it for a couple of years. And is East Teak and ABS still the best places online, or have other reputable suppliers entered the fold? -adam |
