| We are planning to build a small, 5'x16.5', deck. It is about 2' high from the patio.
We are building our patio now by using travertine pavers which are about 1.25" thick. We like them. We are thinking to use them on our small deck as well. We also hope it will reduce the deck maintenance. I have done some research online and try to find a good way to do it. I found those products designed to be used with pavers on the decks are too expensive. I am thinking it may be better to just build a regular PT wood deck and then dry lay the travertine pavers on top of it. Do you think it is a good idea?
- Posted by millworkman (millwork4u@gmail.com) on Sat, Jul 21, 12 at 11:06
| Not an expert but sounds like a recipe for disaster to me. I believe the way your describing this the wood will rot quicker. |
| do you have better ideas? |
- Posted by millworkman (millwork4u@gmail.com) on Sat, Jul 21, 12 at 18:00
| Yeah either buy the products that are designed engineered for this use or build something different. |
