| See pics of my warped decking board below.
I have an IPE Porch and Deck with 2-3 warped boards that have cropped up 3 years later... The boards are attached to the framing via an aluminum T shaped connector that has tongues that slip into the slots on the side of the decking. I'm perplexed as to what I should or could do to repair the decking... perhaps saw the connectors our and replace the board and face screw the new boards in place? All suggestions appreciated. |
| Brad, that's the problem with all of the concealed fastening systems that slip into the board's sides. When the wood moves they can slap out again. Probably the easiest fix is to pry the boards over, use shims to hold them in place, then face screw them down again and plug the holes. After the new plugs weather out you'll hardly see them. |
| Another example of why all of us deck builders preach not to use those hidden fastner systems. Do like Joe says, screw & plug. |
| OK Guys, I get the point. What I was hoping for was some helpful insight on what if anything I could consider doing to force these warped boards back into submission. Ideas? Perhaps a bow-wrench to re-align the boards and then face screw the boards down? bradesp |
| Unless someone has a trick to use a bowrench this way I don't think it would work, you need open joists to hook it on and space to rest it on the side of the deck boards. |
- Posted by john_hyatt (My Page) on Tue, Jul 10, 07 at 16:20
| Joe had a good idea, drive some tapered shims between the boards until they are close to the right place, screw the decking down. This might take several shims,everything is going to want to move as you drive them in,just go slow, watch how the movement goes. You could screw down the few deck boards that are holding to give you something to shim against. Has anyone mentioned its a bad idea to use the clips??? John<<< yucking it up!! |
| A chisel works like the shims, but you have to be careful to not damage the wood. Ipe is pretty hard, so that is not usually a problem. |
| "use shims to hold them in place, then face screw them down again and plug the holes" Why not use duct tape too? Clips are the way to go. You just gotta use the right ones. Ones that actually screw into the wood, at an angle is even better. Using shims and face screws is doing the same thing as a clip just not as well (face screws back out, even with plugs), just slower, uglier and won't last as long. |
- Posted by brooklyndecks (My Page) on Thu, May 21, 09 at 21:01
| tonim, thanks for your 2 year old reply, but... steve |
| Tonim, You say "face screws back out" Please explain how you have observed this. I am intrigued... |
- Posted by john_hyatt (My Page) on Fri, May 22, 09 at 18:47
| I also am intersted in that statement tominster. J. |
