| Hi, gang. I'm sorry to ask yet another permutation of a question that has been discussed a bazillion times. But, after spending 8 months planning and sweating to build my very first deck, I don't want to screw it up now. I've been trying to learn the best way to seal it so that it stays beautiful and solid for as long as possible.
The basic facts are, - 1" cedar deck over PT
Over the course of the project, I have read all sorts of advice, lots of it contradictory. After taking it all in, the harebrained idea that's starting to form in my head looks something like this: 1. bring the cedar decking home from Menards
Am I doing anything stupid? Do I need to wait between bringing the cedar home and sealing it? Are there good reasons not to seal new cedar on all sides? Thanks, David |
| I've never built, or even stained a deck... But in regards to #3, one thing I've seen discussed in my researching for staining my deck is to NOT stain the underside of deck flooring. If I remember right, the reasoning is that as the stain breaks down on the top surface, moisture gets into the wood, then the stained surface on the bottom traps the moisture inside the wood. I know I've read that numerous times on this forum. I believe I've seen Ken respond to this question, but don't remember specific posts. |
- Posted by pressurepros (My Page) on Mon, Jun 19, 06 at 16:13
| David, I hate to do this to do you because I am going to say I wouldn't do anything you are about to do. Here is how I build a cedar deck. 1) Purchase highest quality KD clear cedar from a reputable yard. Why do it this way? John, Steve, Al, jump in here. Maybe I am outta line?
- Posted by gorillabuilder (My Page) on Mon, Jun 19, 06 at 18:00
| my advice would be to get the cedar, (if you want that soft stuff... I'd prefer ipe, because cedar is like cheese. It dents) Store it near the job site for at least a week to acclimate to the environment. If you don't do this and you gap it and screw it down, the wood will shrink and your gaps will be larger than you planned. Or, if you it comes from a dry storage area, and heated garage, it will swell once it reaches moist air. This goes for air or kiln wood because kiln is only good for indoors because it is dried and going in a dry area.(they hurry the process) Even with kiln, it should sit in the house for a week to adapt to the air in that location. Also, air and kiln dried adapt to the environment they are in.. so both should acclimate. 2.I would definitely seal all 4 sides of the wood. Water is in the air in vapor form.. It will aborb into the wood and create an uneven moisture absorption which leads to cupping. It's a pain to seal all 4 sides but it's protecting the board from moisture absorption. Finishing one side is like wearing only a hat in the winter hoping the cold will go through the hat and out your feet. You need 4 side protection. (now, with woods like ipe, cedar, this stuff lasts for decades... Contractors don't typical stain all 4 sides because it draws the process out, it doubles the finishing area and would take a long time to see the mistake manifest) source for the staining of 4 sides, forest products lab. They actually do time-tests) 4. Stain should be applied at least 2-3 warm days after this cleaning in dry weather. if you apply it in direct sun, it can flash dry before it absorbs. So a cloudy, later in the day, application will work best. |
Here is a link that might be useful: Forest products Lab
- Posted by pressurepros (My Page) on Mon, Jun 19, 06 at 20:41
| I still say sealing four sides is a good idea that turns bad. I wouldn't use an oil on the bottom surface of a deck that is 1' off the ground (unless you like mold infestation) Also, I find holes in the theory of evaporating moisture promoting cupping. Rapid wet/dry cycles cause the wood to warp. That would lead one to believe that a wood is better off with a slightly higher moisture content. Say from evaporating moisture? What happens when that top surface of sleaer wears off and water starts penetrating the top? It is going to be trapped. Cedar and water don't mix. The jury is out on this one. I say don't do it. I think it is a complete waste of time. |
- Posted by gorillabuilder (My Page) on Tue, Jun 20, 06 at 0:00
| It is a waste of time.. that's why people don't do it...lol But forest lab did studies on this and staining 1 side just puts a little skin on the board. The entire board is prone to moisture in the air. The bottom especially because it's shady and moisture will hang around there and the wood will breath it in from underneath entirely unprotected without any moisture blocker. This is how cupping starts. The edges is another area that drinks in moisture that's why everyone seals them. The tested way to protect a board is to moisture block the entire 6 sides. You should at least doing this with constructing a deck. As far as maintenance it, you can simply do the top because it will be eaten up by the sun and direct weather assault. Protecting all 6 sides of a board will add years of durability to the wood condition. I have no idea how staining the 'top only'caught on. It's definitely easier but as far as the reasoning of it.. I'm just puzzled. Can anyone post a link to where it says only stain the top because it makes a board more protected from moisture? It's a very popular theory here and I'd like to read more about it. |
- Posted by gorillabuilder (My Page) on Tue, Jun 20, 06 at 1:01
| P.S. I mistakenly said '4 sides' in the first post, I meant 6- 2 faces, 2 sides, 2 edges. Also, I think staining both sides of a deck became such a lengthy task that it was shortened to staining 1 side. It would cost twice as much time, twice as much stain, and twice as much labor in flipping boards, cleaning, staining, waiting for dry weather..etc. Decking material such as pressure-treated, cedar, ipe go many years with or without bottom-staining so it's almost a 'you don't have to'... which turned into a science theory of 'you shouldn't'. Sealing all sides of exposed wood is always a good idea and will definitely protect a board better from my readings. If you plan on building an outdoor bench or arbor with a more delicate wood you wouldn't want to seal just certain sides of it, it would be the whole thing. ------ hardly anyone does it with a deck. I did it with mine but I wouldn't do it for anyone else. lol I also sealed the joist edges and tops, beams, 6x6 posts..etc. It's really a pain sealing a deck, then flipping and doing the other side. I never had a deck board cup and projects were more predictable with acclimating lumber, sealing it entirely, and applying stain on cloudy or late day times. I think if we put the wood in a test area with tons of steam it will curl right up from the bottom with the bare wood, in time. Face-screwing definitely will help slow this process. I don't mean to contradict your opinion pressure-pro's. Your method is what most people do and have no problem for years. I just became a believer in full-seal from the link above at the forest lab, furniture makers and boat makers who specialize in moisture issues. Is this conversation too anal-retentive for a deck? Definitely. lol |
- Posted by pressurepros (My Page) on Tue, Jun 20, 06 at 6:26
| gorilla, No problem, I love a good debate and by no means do I claim to have the perfect answers for everything. Stain manufacturers have been trying for 80 years to get it right and still nothing lats more than a year or two. In a perfect world where everyone did maintenance when they should, used the products they should, and were positively anal about controlling mold growth and were willing to pull up all their floor boards every year to clean and then maybe reseal, sealing on all sides would be a great idea. Just be prepared to seal the top every six months or so and you would be fine. In that same perfect world with no limitations on time or budget, everyone should use 2" x's for deck flooring with a full sanding every three or four years and never use any type of abrasive stripping chemical. Gorilla is right about one thing, many people do get caught up in details that don't really make a measurable difference in the long run. |
| Wow, thanks for sharing your experience, guys. It sounds like you've both had good experiences doing things in pretty different ways. Thanks for the detailed suggestions, pressurepros. I've gone to your site and read up on the RAD system. It sounds impressive, and I'm thinkin about using it. The cedar is already bought and paid for, so I may be stuck with the non-kiln-dried variety from the big-box store. I've made some calls, though, and may be able to trade for KD stuff if it will make a difference. It sounds like gorillabuilder doesn't think it will. What's the advantage you see in it? Thanks for the pointer to the forestry guide, gorrillabuilder. Actually, I love hearing about the science behind what I'm doing. Today I read most of chapter 15 on finishes. You pros probably know most of this stuff already, but it was educational for me. If any other novices are reading this with similar questions, you can find the guide online at http://www.fpl.fs.fed.us/documnts/fplgtr/fplgtr113/fplgtr113.htm Some of the stuff I took away from the guide was,
These sort of supported what I think pressurepros has been saying here for awhile - you don't want to finish the wood in a way that's going to trap water inside. However, the guide also said
What I take away from this chapter is that applying a vapor barrier (eg. paint) to all 6 sides will do exactly what pressurepro is warning against. However, since a water-repellent preservative is not a vapor barrier, applying it to all 6 sides shouldn't have that affect, but should in fact be beneficial. At worst, it sounds like a waste of preservative. If we're all still around in a few years, I'll report back and let everyone know how it worked out. Gorillabuilder, how do you apply the sealer to your deck? Did you brush and flip, or dip the boards? I'm taking to heart the suggestions you guys made to weather the wood a little onsite before installing it. I'm a little nervous, though, because I've had one unfinished board sitting at the site for a few weeks (I had used it as a sample to get a feel for spacing), and it is now *really* warped. If I lay the new boards flat across the joists, though, and don't leave them out in the elements for weeks, maybe they'll hold up better. No one seemed keen on the deck clips, so it looks like I'm stuck with deck screws through the surface. That may have saved me a couple hundred bucks, but it'll expose my imperfectly-aligned and spaced joists. So, my revised plan would be, 1. Bring the wood to the site, lay it across the joists Thanks for sharing your time and experience, guys. David |
- Posted by pressurepros (My Page) on Tue, Jun 20, 06 at 21:41
| The thing I like bout kiln dried lumber is the controlled way the moisture is released from the wood. It is the expansion and contraction of wood through moisture release that causes warping. If you are going to seal the bottom side, which I still say is not only unneccesary but detrimental over the long haul. Be prepared to have an excessive amount of mold undertake your boards from underneath. I would rather see you start with straight lumber, screw it down and keep the top and grain sides sealed to prevent cupping then go on the path of sealing all sides. Your call on that one. |
- Posted by gorillabuilder (My Page) on Wed, Jun 21, 06 at 15:48
| "Excessive amount of mold undertake your boards from underneath." You're saying this because you're thinking stain is food for mildew.. hence it will grow there. But mildew can also grow on wood and the wood itself is the food. |
- Posted by pressurepros (My Page) on Thu, Jun 22, 06 at 9:32
| Moisture is a part of the equation but mold lives and thrives off of an oil based sealer. My only sugestion is to make sure you get a decent brand of sealer with potent mildewcide..nothing from Home Depot or Lowes |
