Getting the 'wet' look
Posted by sacto_diane (My Page) on
Sat, Jun 13, 09 at 15:07
Not directly related to a deck but to a wood porch. I have a T&G Doug Fir covered porch on my 1912 bungalow. It's North facing and deep under an overhang so it stays dry year round and protected from the sun. I've sanded down to bare wood removing old bad paint jobs reveling beautiful old Doug Fir boards.
I refinished with Superdeck transparent penetrating oil finish and it looks great. I'd like to finish it off with something that keeps that wet semi glossy look when the oils are still wet. I don't know if something like exists for finishing exterior wood.
RE: Getting the 'wet' look
The only thing that will give the "wet look" is spar eurathane made by Minwax. Only thing is it is not made for decking, but doors/siding & such. I have done it & it did look really nice for awhile, but wore off fast. You'll get a worn path & the edges will stay nice longer. Don't try the poly, it will crack & peal.
agreed. the helmsman spar urethane will work on spindles and rails, but is not designed to tak foot traffic. Frankly, the only floor grade exterior urethane I know of is by sikkens. Its a true marine grade urethane so It'll last, but It'll run you about 80$ a QUART. not cheap, also, this stuff is going to be real, real slippery, especially in the rain and snow, even with shark grip or some other additive it's not really safe either, just some fyi's
