- Posted by john_hyatt (My Page) on Sat, Jun 5, 10 at 16:25
| In order for the stringers to move down the fasting system at the bottom has to fail. J. |
- Posted by salmon_slayer (My Page) on Sat, Jun 5, 10 at 22:09
| http://www.decks.com/Calculators/Stairs.aspx I would encourage you to keep the risers the same height You can find links to how to build stairs in the link below |
Here is a link that might be useful: deck building information
- Posted by weedyacres (My Page) on Sun, Jun 6, 10 at 19:32
- Posted by sethramesh (My Page) on Sun, Jun 6, 10 at 23:02
| weedyacres: wow. looks great. Thanks you all for the great suggestions. I bought the stringer from home depot. I measured the height and all of them have 6.75" except the bottom one which is 6". How do they sell stringers that does not meet the code? I cut the top one by 1" to be in flush with the header. So the top one measures 5.75". Guess i need to throw these and cut new ones |
- Posted by john_hyatt (My Page) on Mon, Jun 7, 10 at 17:31
| The chance of buying stringers that fit your project are very slim,less than drawing to a inside straight and wining. The box stores can sell any gdf thing they want. Good to see Ya Weed, hows the bike runing. Cut your stringers from 2 x 12. Let me take a little lookie up there... Say you have hmmm 40 '' rise the run can be whatever you want you landing on a slab right? 40'' rise, 16'' treads, 40 '' devided by 5 = 8'' not a bad rise. 16'' treads. If you drop your stringers 8'' from the frame line you need 4 treads. 4 treads will extend your stringers 64'' out from the frame. Short up the treads to 12'' 48'' from the frame line. The conection to the frame is less important than the conection to the bottom plate make that very secure like the Weed Mon did. J. |
- Posted by weedyacres (My Page) on Fri, Jun 11, 10 at 6:57
| Hey Jon Mon, happy spring! I'm not gonna let Mr. Weedy take his bike on a trip without me this year. :-) Seth: Those HD stringers were indeed to code. If you put a 1x6 tread on top, which is actually 3/4" thick, then the bottom step is 6 3/4" from the ground level and each higher stringer, with 1x6 tread on each, is another 6 3/4" from the top of the tread below. The problem is that if the top of your deck isn't an exact multiple of 6 3/4" from the ground, the stringers won't work because you'll have one short (or long) step. I was able to use store-bought stringers because I poured the landing slab at a height that WAS a multiple of 6 3/4". |
