Pouring concrete slab up against stone retaining wall
slc2053
9 years ago
GARDENING AND LANDSCAPING7 Out-of-the-Box Retaining Wall Ideas
Go Beyond Railroad Ties With Stylish Rock, Metal, Blocks, and Poured Concrete
Full StoryLANDSCAPE DESIGNGarden Walls: Pour On the Style With Concrete
There's no end to what you — make that your contractor — can create using this strong and low-maintenance material
Full StoryLANDSCAPE DESIGNPile On Style With a Dry-Laid Stone Retaining Wall
Durable, natural and practical, this landscape feature is an art form unto itself
Full StoryCONCRETEConcrete Block Style
Industrial flair: See why concrete brick isn't just for retaining walls anymore
Full StoryLANDSCAPE DESIGNGarden Walls: Gabion Evolves From Functional to Fabulous
The permeable rock-, concrete- or glass-filled steel cages are showing up as retaining walls, planters, benches and more
Full StoryLANDSCAPE DESIGNGarden Walls: Dry-Stacked Stone Walls Keep Their Place in the Garden
See an ancient building technique that’s held stone walls together without mortar for centuries
Full StoryFLOORS6 Alternative Flooring Ideas to Kick Up Your Style
Rubber, cork, concrete and other materials are worthy options in lieu of hardwood or tile
Full StoryFLOORSFloors Warm Up to Radiant Heat
Toasty toes and money saved are just two benefits of radiant heat under your concrete, wood or tile floors
Full StoryGARDENING AND LANDSCAPINGSunken and Raised Areas Take Gardens Up a Notch
Altering a landscape's grade can create energy and excitement, offering different vantage points and moods depending on the level
Full StoryDESIGNER SHOWCASESA Kitchen Opens Up for a D.C. Show House
Removing a fieldstone wall helps turn a cooking space from dark and dingy to open and filled with light
Full StoryMore Discussions
Centreville Decks, Patios & Outdoor Enclosures · Hot Springs Village Decks, Patios & Outdoor Enclosures · Southampton Decks, Patios & Outdoor Enclosures · Glendale Decks, Patios & Outdoor Enclosures · Hutto Home Builders · Superior Home Builders · Bossier City Flooring Contractors · Campbell Flooring Contractors · Franklin Flooring Contractors · Hazleton Flooring Contractors · Homestead Flooring Contractors · Lawndale Flooring Contractors · Mansfield Flooring Contractors · South Lake Tahoe Flooring Contractors · Saint Petersburg Siding & Exteriors
