New member here. Not a contractor, but a skilled homeowner.
I',m about to build a 340 sq ft Ipe over ACQ deck (5/4 x 6" herringbone pattern)and I have learned alot from your forums and from other forums re: the pros and cons of hidden fasteners versus exposed screws, screws and plugs, etc. I don't want to start another forum about the relative merits.
However, I notived on Starborn's website (while researching their Headcote screws) that they have a (new?) Smartbit package called the Proplug System, which includes a special Smartbit that predrills for the screw and sinks a 5/16" plug hole at the same time. You then blow out the dust, set the headcote screw provided, apply glue in the hole with the special applicator that keeps it from filling the bottom (preventing hydaulic lock and splitting), and tap in the provided (face grain) plug after properly rotating it to align grain. Wipe squeeze-out with a wet rag, and give the plugs a pass with 60 grit after the glue has set. They claim everything is sized to work perfectly together, no need to knowck off proud plugs with a chisel as in the traditional way.
All the info is at:
http://www.starbornindustries.com/proplugsystem/index.html
I don't know if this is completely brand new or not. But it sure seems to cover all the bases, providing the optimal results of traditional screw and plug, with very little more work compared to simple face screwing.
Has anyone used this system? How did it work out for you?
Thanks
Dan Robinson
Comox Canada
dan_robinsonOriginal Author
john_hyatt
Fort Collins Decks, Patios & Outdoor Enclosures · Lafayette Decks, Patios & Outdoor Enclosures · Clearfield Home Builders · Ives Estates Home Builders · West Pensacola Home Builders · Westmont Home Builders · Bridgewater Flooring Contractors · Goodyear Flooring Contractors · Hazleton Flooring Contractors · Honolulu Flooring Contractors · Kansas City Flooring Contractors · Marlborough Flooring Contractors · Owings Mills Flooring Contractors · Liberty Siding & Exteriors · Ramona Siding & Exteriorsgreenearthrecovery
brooklyndecks
duaneber
timk_2010
brooklyndecks
