Application method for sealing ipe
lattelater
13 years ago
BATHROOM DESIGNWood in the Bathroom? Absolutely!
Wet places and wood can be a match made in design heaven — see great examples and get tips for sealing and installing bathroom wood here
Full StoryHOUSEKEEPINGHow to Clean Grout — Stains and All
If your grout is grossing you out, this deep-cleaning method will help it look new again
Full StoryHEALTHY HOMEHow to Choose a Home Water Filtering System
Learn which water purification method is best for your house, from pitchers to whole-house setups
Full StoryREMODELING GUIDESBrick: A Heavyweight for Modern Exteriors
If you picture only traditional homes when you think of brick, it's time to reconsider this modern contender
Full StoryLANDSCAPE DESIGNLandscaping Tricks to Manage Stormwater Runoff
Help rainwater absorb slowly back into the earth with paving grids, gravel beds and other porous systems
Full StoryKITCHEN COUNTERTOPS7 Low-Maintenance Countertops for Your Dream Kitchen
Fingerprints, stains, resealing requirements ... who needs ’em? These countertop materials look great with little effort
Full StoryDECKSDecking Materials Beyond Basic Lumber
Learn about softwoods, tropical hardwoods, composites and more for decks, including pros, cons and costs
Full StoryMATERIALSInsulation Basics: What to Know About Spray Foam
Learn what exactly spray foam is, the pros and cons of using it and why you shouldn’t mess around with installation
Full StoryGREAT HOME PROJECTSWhat to Know About Adding a Reclaimed-Wood Wall
Here’s advice on where to put it, how to find and select wood, what it might cost and how to get it done
Full StoryREMODELING GUIDES'Yakisugi-ita' Is Setting the Siding World on Fire
Exterior wood siding created by a Japanese burning technique is now alighting in the Western world
john_hyatt
salmon_slayer
Coatesville Decks, Patios & Outdoor Enclosures · Gladstone Decks, Patios & Outdoor Enclosures · Miami Decks, Patios & Outdoor Enclosures · New Lenox Decks, Patios & Outdoor Enclosures · North Aurora Decks, Patios & Outdoor Enclosures · Buena Park Home Builders · Anaheim Flooring Contractors · Bend Flooring Contractors · Johns Creek Flooring Contractors · Kansas City Flooring Contractors · Mashpee Flooring Contractors · Monroe Flooring Contractors · Rogers Flooring Contractors · Lenexa Siding & Exteriors · Franklin Square Siding & Exteriors
