| Hi all,
I have a ~5 year old trex deck on the heavily-shaded North side of my house. I do get some black spots and staining as mentioned by so many other here. However I just recently started wondering how much the spacing of the planks causes this... the online install guide recommends 1/4". Mine were install nearly touching, maybe 1/16" at best. Anyone have a sense for how much this contributes to mold, staining, etc? In "wintry mix" weather in the winter the water actually won't drain in a few areas and makes frozen puddles. Any of course it's a total trap for pine needles or anything else. The options I see are: 1) do nothing, keep up with pressure washing 2-3 times/year 2) drill small 1/8 holes in various locations between boards to help drainage with little visual impact 3) Pull up and re-deck with the same planks (major effort!) 4) Use a circular saw to cut a kerf width between each plank lengthwise -- The plank edges are a full radious (aka half round) so I think the saw cut would be "down" in the seam a bit... Thoughts? |
- Posted by martin_carthage (My Page) on Wed, May 6, 09 at 12:11
| I think it's a pretty major contributor. I'd find some way to address it - esp if pine needles, dog hair etc build up in there. Another option might be to follow your p/w with Envirocare Moldex, or the recommendations at cleaningcompositedecking.com This would keep it cleaner between cleanings. |
