| Hello,
I've been researching for a few weeks for options to fix up my old deck (of unknown to me wood). It's pretty damaged, with grooves and cracks all along the floor, faded and worn out stain that shows silvery/grayish underneath, and splintery surface that also has significant wood peeling (if that makes sense). The deck is about 200 sqft, on the second floor with a walk-out basement underneath, and has stairs to the lower level. I posted some pictures HERE. I do know exactly what went on the deck last: Behr Premium Semi-Transparent Weatherproofing Wood Finish (Cedar Natural Tone #501) 100% acrylic. The deck is clearly in pretty bad shape and I'm pretty sure it was not cared for and maintained as it should have been (I've had the house for about a year). The house itself is 25 years old and I wouldn't be surprised if this is the original deck. At the very least, the stairs already show signs of some wood rot though the main level appears solid. While I recognize it may be time to rip the old decking off and replace, I am looking for a way to spruce it up and get a few more years of life out of it, and avoid significant expenses until the full replacement. I plan to focus on the main floor first and then decide what I want to do about the stairs and railings. I'm myself an inexperienced first-hand DIY-er but not afraid of tools and elbow grease and have helped around many home improvement projects in the past. I've been reading a ton about deck options and yet I'm pretty confused about the right steps to take, so I would appreciate some guidance and advice. Thus far, I have honed in on the following steps: 1. Sweep and spray deck with Wolman DeckBrite (percarbonated cleaner).
Besides general thoughts whether the above is reasonable, I'd appreciate guidance on a few specific questions I'm struggling with: 1. Do I actually need to clean the deck before sanding?
I appreciate everyone's time and help! Teddy |
| I'm sorry, but I wasn't able to load the pics. That may be a problem on my end. Anyways, 25 years is a pretty good life span for most wood decks, especially if they are not kept up. That said, sanding, which can be a lot of work, will eliminate the other steps. Put a straight edge on the deck and see how much material you will have to take off, to get the deck flat. If it is too much, use a small orbital sander to get into the areas that the larger sander will not get. If you can pull loose nails, and replace them with screws, that would be a good thing. That will also give you a idea of the condition of the floor joists. If the screws will not hold, that probably means the joists are rotten on the top. Make sure that you use large exterior deck screws. Size needs to be a little larger then the nails, they are replacing Mark |
