Floor Joist Size (above code) recommendation - Ipe Deck
prskier17
13 years ago
CONTRACTOR TIPSBuilding Permits: 10 Critical Code Requirements for Every Project
In Part 3 of our series examining the building permit process, we highlight 10 code requirements you should never ignore
Full StoryGARDENING AND LANDSCAPINGDream Spaces: 12 Decks That Rise Above It All
Tucked into upper levels, these inspiring outdoor spaces provide more privacy and relaxation above the fray
Full StoryLANDSCAPE DESIGNHow to Pick the Right Paving and Decking Material
Once you’ve got the walls or fences of your garden figured out, it’s time to consider the ground surface or floors
Full StoryDECKSDecking Materials Beyond Basic Lumber
Learn about softwoods, tropical hardwoods, composites and more for decks, including pros, cons and costs
Full StoryMOST POPULARWhat to Know About Adding a Deck
Want to increase your living space outside? Learn the requirements, costs and other considerations for building a deck
Full StoryGARDENING AND LANDSCAPINGChoosing a Deck: Plastic or Wood?
Get the pros and cons of wood, plastic, composite and more decking materials, plus a basic price comparison
Full StoryHOUZZ TOURSHouzz Tour: Excavated Waterfront Home in New York
With local building codes limiting its size, a home on the water in Long Island digs deep to discover its beauty
Full StoryPATIOSPatio Details: Simple Materials Make for a Sophisticated Space
Low water bills and minimal maintenance are just part of the beauty of this handcrafted backyard deck and patio
Full StoryBATHROOM DESIGNKey Measurements to Help You Design a Powder Room
Clearances, codes and coordination are critical in small spaces such as a powder room. Here’s what you should know
Full StoryBATHROOM DESIGNHow to Choose the Best Drain for Your Shower
Don't settle for a cheap fix when you can pick a shower drain that suits your style preferences and renovation codes alike
Full StoryMore Discussions
weedyacres
prskier17Original Author
Lebanon Decks, Patios & Outdoor Enclosures · Salem Decks, Patios & Outdoor Enclosures · South Milwaukee Decks, Patios & Outdoor Enclosures · White Bear Lake Decks, Patios & Outdoor Enclosures · Beavercreek Home Builders · Carnot-Moon Home Builders · Cypress Home Builders · McKinney Home Builders · Ahwatukee Flooring Contractors · Ashburn Flooring Contractors · Bradenton Flooring Contractors · Deerfield Beach Flooring Contractors · Maryville Flooring Contractors · Stamford Flooring Contractors · Yakima Siding & Exteriorsdooer
john_hyatt
