PT Pine - sealing and staining
Posted by renna44 (My Page) on
Fri, Apr 16, 10 at 16:21
There's a posting titled something like "I've had it with deck stains"... which is exactly how I feel about my fence. Granted, I'm fairly clueless when it comes to this stuff, but if I could just get a clear picture of what I need to do, it would be FAB-U-LOUS! My dad says one thing, my uncle another, HD another, & I'm so confused.
Here's my question(s) - I am having a 6 ft pressure-treated pine, dog eared fence installed in May. I live in the south, w/sunny and humid summers. I want to have the fence stained a cedar-ish. Ok, so -
Should I wait a certain time frame after it's installed to have it sealed/stained?
Is sealing & staining one in the same? Is there a product that does both? Or is this 2 seperate steps?
Is the purpose of sealing it to help resist moisture? And the stain-- simply eye candy?
What is the best product to use? Something w/an oil in it to penetrate best?
If I use a semi-transparent stain, can I just re-apply stain in a few years when it starts to fade?
thank you - THANK YOU.
RE: PT Pine - sealing and staining
Dont wait for anything but good weather to put the finish on an outdoor project.
Finish will not help the normal factory pannel fence job last any longer than it would with out it because the stringers are not weather resistent lumber.
Quality outdoor finish has uv,water,and mildew protection provided. Using them is a one step deal. I use TWP 100 series.
www.wooddefender.com and www.woodrich-brand.com sell quality outdoor finish as well.
If you are using factory pannels and want to try to extend the life,use one of the above and soak the area where the stringers are in contact with the pickets...a couple of times... then place the finish on the whole pannel.
JonMon www.deckmastersllc.com
