| I'm planning to convert my screened porch into a 3-season sun porch for the winter months.
I plan on using lexan polycarbonate sheets attached w velco so they can easily be removed come spring. Any thoughts or suggestions? I went to HD, got a small sample sheet to experiment with. Looks very clear - nice!
I don't want to glue the hook tape directly on the sheets for several reasons:
If the hook tape is not glued on, I just have to pull one end and strip it off, and roll it up for storage. The hook side won't pick up as much dirt during storage as if I stored the panels with the hook tape on in my dirty shed, and I wouldn't have to flex the panels to detach them. Do you think that this is a good solution?
The porch is exposed to wind and there's no roof overhang.
- Posted by john_hyatt (My Page) on Fri, Apr 30, 10 at 9:28
| Good place for Lexan pannels www.sundancesupply.com I dont give your idea much chance of holding up during a wind storm , driving rain or hot sun. Lexan desplays a lot of movement with weather changes so the install has to allow for that. If your dead set on doing it have frames built for the lexan fasten with screws being carefull / a lot of care to allow them to be backed off durning removal. |
| Thanks, I appreciate your warnings - that's exactly the reason i posted, I don't want to go into this naively. But what is it you don't think will hold up? The glue backing on the Velcro or the velcro's strength? The glue is rated industrial strength and rated for outdoors, wet resistent etc. The surface I'd glue it onto is smooth aluminum. Maybe I'd need a wider strip of Velcro. 1" instead of 1/2". |
- Posted by john_hyatt (My Page) on Fri, Apr 30, 10 at 18:39
| Forget it Girl....by the time you went thru all of that .... A. Your costs will be higher B. Your project will blow away,leak like a sob, look silly and be hard to store. C. Not have the value ratio you want. J. |
| We are ordering 1/8" acrylic sheets, cut to size by a local company, for our small screened porch to make it a 3 season room. After doing the research we learned that lexan will yellow because of the UV rays. The acrylic panels will be about 1 inch larger on all sides than the screens. The acrylic sheets will be installed using butterfly clips on the outside of the screens. We had our contractor put a removable panel on one side of the porch crawlspace and we installed indoor/outdoor carpet on top of weed cloth that we placed right over the dirt in order to have a safe place to store the acrylic panels during the summer months. Our enclosed porch has Lockdry waterproof aluminum decking so the the carpet and acrylic panels will stay dry while being stored. |
- Posted by creek_side (My Page) on Mon, May 3, 10 at 9:07
| Polycarbonate (Lexan is one brand) gets cloudy over time from exposure to UV. You can buy sheets with a UV coating on one side, which will go a very long time before clouding. You MUST put the coated side on the outside. Home Depot used to sell the coated product. I don't know if they still do. Their prices were high the last time I looked. You can usually do better a plastic supply house. Polycarbonate can be worked with ordinary woodworking tools, including drills, saws, and routers. Polycarbonate is very strong and can take heavy blows (bullets in some cases) without shattering. Acrylic, on the other hand, is not nearly as strong and cracks easily, but it does not cloud up like polycarbonate. Special techniques are required when working with it to avoid damage. Drilling a hole can result in cracks radiating from the hole. My vote is for coated polycarbonate. |
