Galvanized nails on fence
catrinka
12 years ago
DESIGN DICTIONARYCorrugated Galvanized Iron
Metal for roofs and walls stays strong and repels rust when it gets special treatment
Full StoryCONTRACTOR TIPSHow to Read a Nail
Learn basic nail types and their uses around the home — plus a historical tidbit you can share to sound like a pro
Full StoryCURB APPEALNail Your Curb Appeal: Traditional Style
Timeless colors, a gussied-up garage and classic door jewelry combine for a good-looking exterior
Full StoryDESIGN DICTIONARYZinc
Zinc, key to galvanizing metal, is a versatile choice for roofing, countertops and more
Full StoryFENCES AND GATESHow to Install a Wood Fence
Gain privacy and separate areas with one of the most economical fencing choices: stained, painted or untreated wood
Full StoryLANDSCAPE DESIGNHow to Choose a Fence That Feels Right and Works Hard
Making a thoughtful fencing choice now can create happiness for years to come
Full StoryORGANIZING8 Incredibly Clever Organizing Tricks
A tension rod under the sink; wire and nails in the closet ... these storage and organizing ideas are budget friendly to the max
Full StoryMATERIALSHumble Corrugated Metal Brings Modern Style to the Garden
This sustainable material is not just for rooftops. See these ideas for using it for fences, beds and rain barrels in your yard
Full StoryLANDSCAPE DESIGNGarden Walls: Gabion Evolves From Functional to Fabulous
The permeable rock-, concrete- or glass-filled steel cages are showing up as retaining walls, planters, benches and more
Full StoryMATERIALSShould You Use Composite Timber in Your Landscape?
This low-maintenance alternative to wood is made from varying amounts of recycled plastic. Consider it for decks, fences and more
Full StoryMore Discussions
millworkman
mike_kaiser_gw
Algonquin Decks, Patios & Outdoor Enclosures · Billerica Decks, Patios & Outdoor Enclosures · Chicago Decks, Patios & Outdoor Enclosures · Gladstone Decks, Patios & Outdoor Enclosures · Pittsburgh Decks, Patios & Outdoor Enclosures · Spokane Decks, Patios & Outdoor Enclosures · Griffith Home Builders · Yorkville Home Builders · Beaufort Flooring Contractors · Bellevue Flooring Contractors · Bethpage Flooring Contractors · Land O' Lakes Flooring Contractors · Poughkeepsie Flooring Contractors · St. Louis Flooring Contractors · Wyoming Flooring Contractorsaidan_m
