| A previous homeowner painted our deck with Porch paint.
What's the bet shot at removing it? It seems to peel up fairly easy, though I suspect some areas will be more stubborn than other. Do I need a stripping chemical or just an orbital sander? If the wood underneath is stained is there some sort of stain I can use to better deal with inconsistencies in wood color? Like a gel stain or something? |
- Posted by North_Andover (My Page) on Tue, Mar 29, 11 at 12:20
| I would start with a pressure washer> If it is already peeling it should do a pretty good job. You then can follow up with an electric sander. |
Here is a link that might be useful: Andover real estate
- Posted by booneunderpressure (My Page) on Thu, Mar 31, 11 at 13:44
| Tancefusion, Sorry to hear about your painted deck, but there is a solution. Although it is peeling off, don't just try to blast it off with a pressure washer...yet. N Andover is right it will help, but you need to do a few other things first. A chemical strip (sodium hydroxide in powder form) mixed with water. This is CAUSTIC stuff & can be dangerous. Please heed caution. Can't get it just anywhere, but I promise this will work. I've stripped 4 layers of paint/sealer with it. Stay away from the gel stripper. It's messy & quite expensive. The key to stripping is using the right products & dwell time (45-60 minutes) while keeping it wet. The idea is let your stripper do the work, NOT you. Now, you low pressure (500-700 psi) wash & rinse the paint off. You'll then need to neutralize the stripper w/ oxcilic acid & rinse after about 30 minutes. Should also brighten your wood. Then lightly sand w/ 60 grit if you're going to stain/seal. Let me know if you have any questions & how it turns out. The deck guy |
- Posted by Walt(walter.hand@cinbell.com) onMon, May 9, 11 at 9:19
| Just wanted to stress that sodium hydoxide--Caustic Soda is mean stuff, & that it gets the job done. I loaded it in a railyard from railcar to trailer for 5 years. We were dealing with industrial strength, you wont be. Here are a couple of safety tips |
