Sat, Mar 20, 10 at 10:58
| We are putting in a 400 square foot patio and were planning to put in 4 inches of gravel (crusher) and 2 inches of sand under the 16 inch patio pavers. Then we were told by one of the stone/sand/mulch companies we spoke to that they don't think we need the sand and that when they do patios they never use the 2 inches of sand underneath--just 6 inches of gravel. I just wondered if anyone had heard this. I assume we will use the sand, but it would be cheaper not to use it. |
- Posted by huskyridor (My Page) on Sat, Mar 20, 10 at 20:40
| I use 6 to 8 inches of crushed concrete as my sub base under patio pavers or flagstone decks if my buyers don't want to pay for a concrete sub base. Then I put 1/2" to 1" of masons sand or torpedo sand, after placing my patio pavers I sprinkle masons sand in between the bricks, lightly water, and repeat the process. You can also use crushed granite or a 3 sack stabilized sand as your sub base. See ya, |
- Posted by gideonsmom (My Page) on Sun, Mar 21, 10 at 12:04
| Thanks! That's what most of the DIY websites said too! (I forgot that we were getting 2 inches of sand so we'd have 1 inch under the crusher run and 1 inch to sprinkle.) So I guess we stick with our plan. |
- Posted by weedyacres (My Page) on Mon, Mar 22, 10 at 10:35
| Yeah, you need sand to set the pavers. Sand is easier to level and makes a more solid base than gravel. You don't need a 2" layer on top of the gravel, but you need enough to make the base level. |
- Posted by Margaret Hawkins(shehawk@grandecom.net) onMon, Aug 1, 11 at 13:39
| Am putting down pavers in a row for a pathway. After I put in the sand, should I water/sprinkle it to firm it up or is just putting in the sand (about 2" worth) & then putting the paver on top enough? |
| me, i would use 2 inchs of fine gravel you can get on top.sand could wash away over years etc and gravel will still be there. i never see sand on top,always fine gravel. |
