is an ipe deck installation different from other woods???
jaansu
12 years ago
Featured Answer
Sort by:Oldest
Comments (6)
aidan_m
12 years agojaansu
Little Rock Decks, Patios & Outdoor Enclosures · Manchester Decks, Patios & Outdoor Enclosures · Meridian Decks, Patios & Outdoor Enclosures · Spokane Decks, Patios & Outdoor Enclosures · Troy Decks, Patios & Outdoor Enclosures · Chula Vista Home Builders · Cliffside Park Home Builders · Farmington Home Builders · Lynden Flooring Contractors · Stoneham Flooring Contractors · Suwanee Flooring Contractors · Wyoming Flooring Contractors · Columbus Siding & Exteriors · Fairfax Siding & Exteriors · Western Springs Siding & Exteriorsaidan_m
12 years agojaansu
12 years agoweedyacres
12 years ago
FENCES AND GATESHow to Install a Wood Fence
Gain privacy and separate areas with one of the most economical fencing choices: stained, painted or untreated wood
Full StoryCONTRACTOR TIPSContractor Tips: Countertop Installation from Start to Finish
From counter templates to ongoing care, a professional contractor shares what you need to know
Full StoryPATIOSSpring Patio Fix-Ups: Install an Outdoor Fireplace or Fire Pit
Make your yard the place to be by adding a fire feature that draws a crowd
Full StoryMATERIALSThe Most Popular Roofing Material is Affordable and Easy to Install
Asphalt shingles, the most widely used roof material in the U.S. are reliable and efficient, and may be right for you
Full StoryREMODELING GUIDESContractor Tips: How to Install Tile
Before you pick up a single tile, pull from these tips for expert results
Full StoryHOUZZ TVHouzz TV: How to Install a Rain Barrel
This DIY tutorial shows how easy it can be to capture rainwater from your roof to use in your garden later
Full StoryMOST POPULARSee the Difference a New Back Deck Can Make
A dramatic 2-story porch becomes the centerpiece of this Ohio family’s renovated landscape
Full StoryTILETop Tile Trends From the Coverings 2013 Show — the Wood Look
Get the beauty of wood while waving off potential splinters, rotting and long searches, thanks to eye-fooling ceramic and porcelain tiles
Full StoryWINDOWSContractor Tips: How to Choose and Install Windows
5 factors to consider when picking and placing windows throughout your home
Full StoryFLOORSWhat's the Right Wood Floor Installation for You?
Straight, diagonal, chevron, parquet and more. See which floor design is best for your space
aidan_m
