Sun, Feb 19, 12 at 14:30
| Ventilation is a serious problem. IPE will rot and warp if moisture trapped underneath. Requires adequate airflow to prevent condensation build up. While IPE is otherwise as close to indestructible as any wood can be, it is vulnerable to moisture and is specifically not rated for ground contact for this reason. If you use it on a rooftop deck, you should make sure there is airflow underneath. This may require vents on the house side and opening on the outside end of the deck with support rafters running outward (so air can flow under the boards.) I would also use as wide a board spacing as practical. Use of 5/4 board thickness would would slightly decrease the odds of warp/cupping and allow wider rafter spacing for better airflow. Most important issue is whether you can raise the deck sufficiently to allow adequate airflow underneath. If not, IPE not a good idea. (I do not know about Massaranduba) |
- Posted by scotter1975 (My Page) on Sat, Mar 3, 12 at 15:23
| Thanks for your advice Zver. I hear you about the circulation issue. At the least I will have about 16' of space between the deck and roof, and about 36" at the most. The roof is sloped about 2' from left to right,so at least there won't be any standing water underneath-and clearly there will not be any moist soil underneath. I'm hoping this will compensate for the lack of clearance above the roof surface. Would you recommend drilling 3" holes into the Support Beams for improved circulation? Would doing so compromise the structural integrity of the deck? |
