Fri, Dec 16, 11 at 18:56
| I searched the forum but did not find the answer to my particular problem. Hope someone can help.
Background: I installed my MinMax in 2005. It is only used a few times each year. About a month ago I had my pool and spa re-plastered with pebble tec. I replaced my pool pump yesterday with a Pentair VS unit. Today I tried running the heater, nothing happens. The only error is one blink from the red LED inside the case which indicates an Air Flow fault. I ran a wire in the fittings at both ends of the air tube as suggested by repair guy in another post. I also cycled the power as suggested, again, no go. The power and pressure LED's are both green, I ran the pump from 900 rpm all the way up to 3100 rpm, made no difference. Any suggestions would be most appreciated!
- Posted by muddy_water (My Page) on Sat, Dec 17, 11 at 8:43
| This is the best place to go for Pentair equipment problems |
Here is a link that might be useful: Pentair
| Most likely a dying fan. The air switch is generally quite reliable. Is the air line from the switch to it's manifold port connection properly connected and intact? Scott |
