Mon, Dec 6, 10 at 15:20
| If I have spa booster pump that also doubles as a waterfall pump with 2JVAs, does it switch the JVAs every 15 minutes like it does when spa is freeze protected if we check the default mode its set in? Does that mean that any JVA switches every 15 minutes that is checked? |
| Any resolution? This inquiring mind wants to know, Scott |
| It took awhile but here is the answer. Spa is the only function that switches the valves back and forth on the timed basis. I also inquired about the approximate number of times the JVA motor and valve could move before they reached a failing point but they didn't have an answer other than to say that it was a very infrequent failure. |
| So if you wired the spa-booster/waterfall pump as the primary pool and spa combo's pump and the pool's pump as a water feature pump, wouldn't that meet your needs? Scott |
