Urgent question regarding spa
Posted by lpge40 (My Page) on
Sun, Nov 4, 12 at 19:02
Hi there,
Just started the installation of a fiberglass pool 16x40 and tomorrow they are starting the plumbing and electrical. Pool will be delivered tomorrow too. The pool hold 21000 gallons and we have the Pentair intelliflo pump, pentair 320 clear and easy, intellichlor IC40 and pentair 125000 heat pump.
We had not budgeted for a spa but yesterday I mentioned it and the pool builder said he would give us a good price as he already has dug up the area and is about to start the plumbing, electrical etc.
He mentioned he would include the light, the pump, add as many jets as we'd like (?) and obviously the plumbing. The spa hold 500 gallons.
The question I had is what should we be looking for as far specifications are concerned. Pump size? Seperate plumbing? I'm clueless as this is last minute and haven't really researched this.
Or would it just be better purchasing an above ground spa later?
Thanks!!!
RE: Urgent question regarding spa
I don't build fiberglass pools, but I can tell you that I use the one Pentair Intelliflo VS3050 pump for both the pool and the spa. You can't have the jets in the spa going when the pool returns are on, but that is no big deal. The Intelliflo pump will operate as efficiently as possible if you use 3" suction line plumbing on the spa. Besides a light and jets and pump, you need an air blower to power the spa jets, but those are inexpensive. I can't imagine how your PB could be providing this to you at no additional cost, but, what the heck, I'd go for it if I were you,
Womanowned, much obliged for the quick response. He may have mentioned the air blower, not sure. I was also wondering if one could keep the spa at a certain temp separate from having to heat the pool if you only have one heater?
