| We are buying a house with a 15 x 30 pool and it was left full for 3 years. The pump was removed. The pool has a 2 x 6 framework over it, and remnants of a plactic cover (visqueen?)
The water looks black, from what we can see. Not much light, and can't get too close to it. Is draining it, cleaning, pressure testing the piping, the way to go, before installing a new pump? Is it sane to think the pool could be cleaned without draining?
Thanks for any help |
| Where you are located is important. Please tell us. What type of pool? Vinyl, Plastered or painted, or fiberglass? Do NOT drain it! It can be cleaned without removing the water. That can lead to other expensive issues. If your pool is in a Northern climate, there are significant freeze concerns. A safety cover and waiting till later in the Spring would be highly encouraged. There are scoop nets to remove organics like leaves and sticks. Scott |
