| I have a hot tub that I havent used for 1-2 years and it has been sitting inside. The pool place sold me on a quart of spa purge made by national chemistery. She said to add the whole bottle to the unit and run it for 30 minutes and let it sit for 24 hours. I did and it foamed up and started running over within a few minutes. Im now wondering if she knew what she was talking about. Advice please. |
| Take careful note of the instructions and part 3. about the foaming........... Reading the bottle instructions would have shown you part 3 as well. |
| The best way I know is to hyper chlorinate for several hours and then dump the water. Refill, dump again after running a couple minute and refill. Put in new filter elements and balance following the instructions found on either Trouble Free Pools or Pool and Spa Forum (better for spas I've found but TFP is still excelent). Scott |
- Posted by coastal_concepts (My Page) on Thu, Nov 24, 11 at 1:21
| Specifically you need to use a line flush product to remove any potential bio-film in the plumbing lines...of which there is likely plenty. The best commercial line flush product I have used is made by Aqua Finesse however the Spa Guard brand swirl away pipe flush is also good. Foaming is an indication of garbage/oils in the water. Be sure to take the filters out of the tub as they do not need to be in while flushing your lines and can deposit detergents and oils in the water which will promote the foaming. Dump the water and refill and THEN you can flush the pipes again which maintaining 10ppm of sanitizer overnight. This will help to get the tub really clean and minimize foaming during the cleaning process. Also consider reading the Spa School link below and learning about proper hot tub maintenance |
Here is a link that might be useful: Spa School
| When all else fails read the instructions :~) |
