Fri, Oct 29, 10 at 19:40
| Today was a banner day. The pool builders installed the pool krete floor to my vinyl liner pool. About one-half hour after they left, my OCD kicked in and I decided to rinse off my patio. The water runoff ran down the back of my polymer wall panels, and found the path of least resistance. This path was of course the gap between the pool wall, and the clay bottom of the pool. While the pool krete covered this gap, the pool krete was not yet dry. In two places the water washed the wet pool krete out of the gap, and caused an erosion crack about three feet long, couple of inches deep, and a couple of inches wide. Will they simply be able to fill the crack in with new pool krete, or is this a bigger deal. While you can do nothing for my stupidity, and I am hoping you can help put my mind at ease. Thanks in advance, Adam |
| afncards, This is easily fixed. Don't worry. Good luck. |
| What is the fix?? |
