Hey sorry it has taken a while but I was distracted by Hurricane Sandy. Anyway the problem more than likely is that the flow switch is not pointed in the correct direction. You have to make sure the arrows molded into the top of of the flow switch are pointed in the direction of the flow of water through the pipes(see image attached). It is a common mistake to overlook this important indicator. If you adjust this it should solve your no flow problem and everything should work as intended.
domingos35Original Author
Aegean Pools, Inc.
Pflugerville Swimming Pool Builders · Randolph Swimming Pool Builders · La Marque Landscape Architects & Landscape Designers · South Orange Landscape Architects & Landscape Designers · Mooresville Landscape Contractors · Wilmington Landscape Contractors · Del Aire Landscape Contractors · Pacifica Landscape Contractors · Riverhead Landscape Contractors · Kissimmee Decks, Patios & Outdoor Enclosures · Lebanon Decks, Patios & Outdoor Enclosures · Liberty Decks, Patios & Outdoor Enclosures · Little Rock Decks, Patios & Outdoor Enclosures · Salt Lake City Decks, Patios & Outdoor Enclosures · Windsor Decks, Patios & Outdoor Enclosures
