Spa Jet & Pump questions
Posted by jsjames (My Page) on
Mon, Oct 17, 11 at 17:14
Hi -
I have a pool/spa that was built in early 1990's. It has a separate Spa pump to power the Jets. The jets plumbing is 2" PVC and the pump is located ~50ft away from the spa. There is a separate drain for this pump and it is not connected in anyway through the filter or heater. I don't have any special "jets" in the spa, they just look like 1" i.d. PVC pipe that are exposed throught the gunite. The original pump was a Challenger Pac Fab 2HP - and I was getting good jet action with this pump.
The original pump broke down and I plumbed in a Whisper Flo (WFE-4) which I had in the garage. In looking at the pump performance curves, the Whisper Flow has a little less flow (10-15 gpm, depending on TDH) and so I expected a little less jet power, however, the flow seems considerably less which surprised me.
see performanc curves here:
curves
Question: Would a total 10-15 fpm flow rate (1-2 gpm per nozzle) make that big of a difference on the jets?
To increase the flow rate, I've read that I can change out the WhisperFlo motor and impellor. I'm thinking about changing those out to get to 2HP (WFE-8). I've read you need 1/4 HP per jet, however the distance from my spa->pump seem long.
Question: Any issues in just changing the motor/impeller on the Whisper Flo to get the increased flow?
Question: Does 2HP WhisperFlo seem like the right choice?
Question: Is a larger pump required given my distance from spa->pump?
Many thanks for your help!!
Jeff
RE: Spa Jet & Pump questions
6 or 8 jets?
You went from a 2 HP pump to a 1 HP pump. You're going to lose more than 10 to 15 GPM with that change. More like 20 and yes, that will make a significant difference in performance.
Swapping with a full rated 2 HP motor, changing the impeller and seal set will return your performance. You might consider though, a two speed motor so the power used in normal circulation is reduced.
Scott
Hi Scott - Thanks for the reply.
I have 8 jets.
Regarding getting a 2 speed motor, I don't quite understand why I would use a lower speed for circulation. The "primary" pump motor (which is variable speed) is the one that circulates the water through the filter & heater.
Thanks again,
Jeff
I missed that this was the spa booster. Then the 2 HP is what you should be using. Especially since there are 8 jets, likely basic Waterway jets.
A 1HP pump trying to push through a loop is going to meet a substantial head loss.
If you have ever seen a pool with attached spa that uses the circulation pump for the spa, you would see the pressure in the filter increase, often by as much as 10 PSI, indicating a significant resistance was being met.
Scott
