Tue, Oct 18, 11 at 14:04
| Howdy again. My toddler threw dirt clods into the pool. (Yep, it's fenced, but he has a good arm. And nope, he won't be doing it again.)
I can't scoop them out because they dissolve. So, do I just sweep the dirt towards the drain, turn up the pump, and plan on cleaning the filter sooner rather than later? I assume this isn't an unusual occurrence...anything else I should do? Thanks! :) |
| I would suggest you vacuum it out manually. Scott |
