led lights
Posted by azbigdaddy (My Page) on
Sun, Oct 10, 10 at 11:25
I have a easy touch 4 controller that operates my pool and spa which is about two years old. Recently I noticed that the led lights on the same circuit, one in the pool and one in the spa are not the same color. For example when white is selected for the color the light in the pool is white, the light in the spa is a yellow/orange color. I have tried the "sync" selection from the lights category, but it doesn't seem to make a difference. Any advice would be appreciated.
RE: led lights
Sounds like the spa fixture's internals have a failure. What about other colors? Does the pool continue to show the chosen color and the spa incorrectly?
Scott
RE: led lights
The other colors are off a little bit also. The pool light always shows the correct color. All the pool equipment is Pentair so I believe it is covered under a 3 year warranty.
RE: led lights
I believe the "sync" function applies to lights on differing circuits.
Assuming the two lights are of the same generation and have the same sequence of colors/modes, then I think you might have to disconnect one and manually switch on/off until it gets around to a match, then hook together again.
Of course if they fix it for free under a warranty claim = WIN.
