- Posted by topfiftybuilder (My Page) on Mon, Sep 27, 10 at 20:13
| I think the hydraulics need to be better thought out... the vanishing edge alone will create a tremendous call for water volume... I wouldnt suggest hooking it the the existing plumbing ... given the size you could put a small filter setup on it... |
| Keep it simple and by itself. Own pump, filter, etc... If you have automation, it will likely need some sort of update for dual equipment. It may be s/w or hardware, Scott |
| It's really not that complicated. With all of the stuff you already have, I would put this on it's own pump. I would configure it like this. Install 2 2 1/2" suctions in the side of the existing pool pool. Run them to a variable speed pump. Run a return line to shallow pool, and put 3 way valves on both the bubblers, and sheer descent. The flow rate required for the negative edge will depend on what you want it to look like, but typically a flat weir likes 3-5 gpm per foot of weir which a 20' weir would require 60-100 gpm. Keep in mind though, that this feature doesn't always need to run. If you have a controller you can cycle it automatically for a few hours a day. You can then crank it up for party mode. This system wouldn't require a skimmer because the negative edge till do this for you, then the pool skimmers will pick up the rest of the crud. You might be able to use the existing pump with a little compromise, and ingenuity.
| Racket: The vanishing edge won't spill into the pool, just a drain. What are my options there? How would I plumb that? If I eliminated the vanishing edge, could I just tap into my existing PVC suction and return lines? What would that setup look like? |
| Personally I would have it roll over into the pool. It would be easier to install. |
| To not drain into the pool but into a catch basin would make it almost mandatory to use separate equipment. Scott |
| You can run equalizer pipes into the pool from the catch basin. |
| With a single filter system, thats a lot of water to equalize by gravity. I would expect to use about 25-30 GPM for a nice wet edge Going to need some elevation too. The catch basin can't be below the pool level so the water returns. New holes in the pool shell too for the returns. Scott |
| thejimbar...cool design and idea. You will like the shallow water for soaking you're feet and lounging while watching the kids play. A few thoughts as it relates to our experience with a large shallow area of the pool. Ours is about 4" deep and 10'x20'. 2. If you think you will use this shallow pool more in the off-season than the regular pool, you should consider this when deciding to tie it into your existing pool. If you winterize your pool, it will be hard to do so and still keep the shallow pool in operation longer if it is tied together. 3. On the other hand, tying the two together will give the added benefit of heating the primary pool also, if the shallow pool is located in a sunny area of the yard. 4. If the decision is to tie them together, technically, it's possible to do so and still keep the two bodies physically separated from one another as you originally wanted. The equalizer line would have to be sized rather large (and likely multiple lines needed) to keep up with the passive flow from one body to the other during high flow requirements in the shallow body. 5. Would also recommend a separate pump for the negative edge pit if you already have water features that require flow with your existing pump...nothing more aggrevating than hosting a party and not being able to use all water features at the same time because of pump limitations. 6. We love our 4" shelf for the heating benefits and soaking your feet any time of the year. We also love our bubblers in the 4" water...nothing more relaxing than sitting in a chair with your feet being massaged by water coming from the bubblers in the floor of the pool (that's what I'm doing right now). We have a separate pump for the bubblers, aerators and deck jets also. 7. Connecting the overflow from the negative edge directly to the pool would be the easiest way to tie the two together..much like an oversized spa and no need for equalizer line. This may not meet your original vision though if you were thinking of keep the 2 bodies physically separated. One last thought, if you keep the 2 bodies separate from one another, then the new pool will have to have it's own filter and sanitizing system. If you tie them together, it will save cost but you will not be able to winterize one and keep the other open. They will have to be closed at the same time...if you close the pool at all. Oh..one more thought...size the negative edge pit so that you can fit your favorite leaf skimmer in it to scoop out leaves and debris easily...all the debris will end up in the pit and you'll want to skim it easily. Decisions....decisions. Hope this helps. |
- Posted by huskyridor (My Page) on Fri, Oct 1, 10 at 2:27
| This is easily achievable with your existing equipment if you have an Aqualink controller. All you have to do is plumb into the suction pipe immediately prior to the pump with a 4717 and into the return immediately prior to the existing 4717 for pool/spa return. Place JVA's on these new 3-ways and plug them into the cleaner and solar JVA sockets, go into JVA assigns in the menu and assign both to the extra axillary. Note, You must relocate your current chlorinator or salt cell into the return pipe prior to the new 3-way. Give it a twice a day program with at least an hour a day each, you may need to increase these times to keep a solid FC in your new body of water. Your catch basin should at least be an equal, but preferably more, amount water than the shelf. Place a skimmer, to deal with the debris, on the basin and use an autofill such as a Poolmiser or a Levelor to control it's water level. This is, truly, a walk in the park for an experienced swimming pool plumber. I've done this for buyers many times without problems for those who don't want purchase a filter/motor/controller for the new water feature. See ya,
| Thanks for all the inpuut, lots to digest here. Going to scrap the vanishing edge idea and look at Kelly's suggestion to tap into the existing. I have Jandy equiipment and could easily add a few electronic valve actuators to the system. Kelly, would like to control the spillover and be able to control the bubblers. Also need a skimmer now. Does this need small floor "drains" as well? I will of course go to my PB, but I'd like to understand it all before I talk to him. How would I plumb all this? Here's a photo of my existing setup. |
- Posted by huskyridor (My Page) on Fri, Oct 1, 10 at 19:48
| IMO, If you scratch the catch basin you'll need to make your depth more than 8", this just won't have much water in it. I'd go 15" on the flanks sloping to 18" in the center at the drains. Place a stalked fountain like the waterstar from Polaris or search for some telescoping fountains that will recede back into the floor when sitting idle. First thing you need to know is what controller do you have and is the Solar still available or is it occupied? Second, yes you'll need a skimmer and a drain. You can do it on drains only but be prepared to dip a bunch with your leaf net. Third, you'd be best served going to your, or any other, pool builder. Fourth, you'd plumb in the suction side 3-way in front of the pump between it and the pool/spa suction 3-way and the return would be immediately after the salt cell and before the pool/spa return 3-way. You'll also have to rotate your existing JVA's 180 degrees and recalibrate the orientation of your valve handle swing. You'll probable have to remove the old style Tee sensor and use the port at the bottom of the cell and remove the coupling in front of your pump. It doesn't look like there's enough room to place a 4717 sideways in the amount of pipe you have showing. The only thing to understand when you perform this is that ALL of your available suction and return must be removed from the pool/spa while the pump is running and that the pool will sit completely idle while the feature is on. You cannot co-mingle any of the two different bodies of water or you'll risk flooding over the features coping or cavitating the pump from losing water in the feature. See ya, |
