Wed, Sep 21, 11 at 8:33
| Have 2 JVA's that control pool/spa combo. This AM awoke to empty hot tub. Noticed JVA2444 that shuts down skimmer side was in wrong position. Appeared to be stuck. Got it to move manually but now when I go to SPA setting, it rotates 360 degrees and does not stop at the point where it shuts of skimmer/main drains. How do I get this reset so it stops in the correct place? Did I damage cams by turning it manually? Didn't realize there was a switch below to do this....Any advice appreciated. |
| Le Manual. http://www.zodiacpoolsystems.com/Products/Valves/Valve-Actuator.aspx |
| Sounds like the cam inside is either loose or the microswitch the cam is supposed to bump is broken. Scott |
