Basketball hoop
Posted by GoofyYno (My Page) on
Mon, Aug 29, 11 at 23:43
Why are the deck mounted basketball hoops so expensive? the ones with bases seem to cost less- I know they are not mades as well, but I'm broke after building the pool:(
also, why to target and walmart only sell theirs via internet. Normally I wouldn't care, but I need something by labor day.
RE: Basketball hoop
If you have a Leslies pool supply near you, they sell a decent one with a base for $100 and you can usually find a coupon for $15 percent off.
RE: Basketball hoop
That's the problem- I put in a sleeve for the pole, but can't find a cheap hoop for it. seems silly to get one with a stand now. Can you remove the stand, and just put the pole in the sleeve? or maybe I can just buy a pole and attach a acrylic backboard?
I think Leslie's is the only place that has anything around here. I will go buy there on Thursday when I'm off.
RE: Basketball hoop
You could always make one.....
A buddy of mine constructed one out of a worn out umbrella pole. Used plywood as the backboard, and a simple rim/net to finish it up. Said it was pretty easy, and obviously pretty cheap.
May not last as long as a plastic one, but should last a couple of years at least.
