Sun, Aug 22, 10 at 22:56
| My PB put in a cleaner line for future use if needed. The line is currently capped at the equipment pad but open in the pool. She I plug this line at the pool end too? Will some place like Leslie's have a cap for it? The fitting in the pool has threads. |
| You should of plumbed it into your suction, this would allow you to vac the pool if needed. If you use it or not you want to install a vac-loc cover over it. Leslies sells these. |
| Well, no need to hook it up if you don't have a suction side cleaner or don't intend to get one. If you do have/or intend to have one, then hooking it to the system will be a convenient thing. If you don't intend to use it just now, the threads should be a standard 1.5" PVC connection and any type PVC screw-in fitting from Home Depot/Lowe's will work. |
