JOIN NOW LOG IN
Can't find inground pool leak.
Posted by javajnkie (My Page) on
Mon, Aug 24, 09 at 17:34
Hi,
I hope you all have some ideas, because this phantom pool leak issue is driving me completely insane! I've lived here nine years and haven't had any real problems with the pool until this year.
Here's the story: The pool is a rectangular, 16'x36' vinyl-lined in-ground pool (the liner is over concrete? concrete/vermiculite mix?). It was built sometime between 1973-1975. There is no main drain at the bottom of the pool.
Since I opened it this summer, water has been pouring out onto the street from my waste/backwash pipe. Initially, the pool was leaking down to the point of the return and intake ports, so I assumed the leak was coming from there. The return port gasket was bad, and since I had patched the liner in the corner last year, I figured that probably had something to do with it too.
So I bit the bullet and $3500 later, I have a brand spanking new liner. They installed it last week and by Thursday, I had it refilled and ready to go. I thought. Then the city knocked on my door to ask why water was pouring out to the street. By Friday night, the water had dropped down to the return and suction lines. By this morning, it had dropped another 5 inches and is at the bottom of my second step.
The pool guys who installed the liner came out this morning and dye tested around the stairs and the ladders. He couldn't find anything and is completely confused (as am I) as to why it's pouring from the waste/backwash line when the pool water level is now well below any plumbing.
He's coming back with some machine to test the liner for leaks. He doesn't expect to find any.
The concrete patio area around the pool looks fine (no new cracks, no sinking, etc). The grass around that looks fine (no soggy areas, no patches of dead grass, etc.). The pool equipment is housed above ground in a shed about three feet from the pool. The pump runs fine when the water is at skimmer level--there doesn't seem to be any suction loss or bubbles coming from the return line. Of course, it only runs fine for a day, because the water level is dropping so quickly.
Does anyone have ANY ideas? The only think I can think of is an underground plumbing leak, but the water level is too far below any plumbing now for that to make any sense. I suspected a leak around the fiberglass stairs...except that the water is coming out the waste pipe!
I am at a complete loss. I'm a widow with two young kids at home and three kids in college; I just don't have another large chunk of cash to put into fixing it! I was really hoping a new liner would solve the problem! Much to my kids' dismay, I'm considering just filling it in with dirt if this is going to be an expensive fix.
Although I hope someone will write back to say "no worries! This happened to me and it cost me $20 and two hours to fix," I doubt it'll happen. But I'm crossing my fingers!!
Ideas??
Thanks in advance,
Mari
RE: Can't find inground pool leak.
No worries!
You most likely have a bad spider gasket in your multiport valve. This is a very simple and common repair. Any serviceman with limited experience should have figured this out.
I'd be so happy if that were the problem! :)
However, I checked the multiport valve when the water level was high enough that I thought some could be leaking out there. But now the waterline is feet below the skimmer and intake and return valves and the pump is off, so there's no water being routed through the lines by the multiport valve on the filter.
However, when the water was at skimmer level and the leak was first noticed, I covered the skimmer faceplate to isolate the water in the skimmer line and see if the leak was coming from there.
It isn't. Today, the skimmer still has water in it.
I'm absolutely confused as to how the water is leaking out the waste line when it's so far below any plumbing!
In order for the water to go out the backwash line, it has to go through the multiport. If you don't have a sight glass on the multiport or the backwash line, you won't see any water going through the valve. If you have turned off your pump and water continues to come out the backwash line, then it is siphoning out through the multiport. This would happen if the end of the backwash line is below the water level in the pool. You can either open the air relief valve on the top of the filter, unscrew the sight glass or cut the backwash line after the multiport to stop the siphoning.
I am 99.9 % certain that the problem is with the multiport. The multiport valve is the one with the spring loaded handle that has different positions or notches that the handle fits into. The handle is the one you change positions to backwash the filter.
Hi,
Thanks for your response, and I'll check the multiport valve again. But the water in the pool is BELOW the level of the pump, filter, AND the end of the waste/backwash line! The reason the "pool guy" and I are so confused is that it makes no sense for water to be going there at all, since there's no logical way for the water to even reach any plumbing line now. On top of that, the valve and site were opened two days ago, which if water were being routed through the filter would have broken any suction by introducing air into the line.
It's dropped more and I have only about 10,000 gallons of water in the pool at this point--there's about 4" in the shallow end. The waste line is now trickling water instead of gushing it...but it's all very illogical. :/
They're coming out tomorrow afternoon to do more leak detection. In the mean time, I'll completely disconnect the waste line from the pump.
I wish I had a schematic drawing of my pool's underground plumbing though.
Dear Java,
I'm guessing you have a pool light, if that is the case, I'd give you 5:1 odds that's where your leak is. What happens is, the conduit that your submersible light wire runs through gets cracked due to normal ground shifting and settling. Nothing to worry about, we see it all the time. We use "toilet bowl wax" for its tacky properties as well as easy removal the next time you have to remove your light.
Remove light, should require removing 1 screw, 2 at most. (Do not remove the light ring) the light probably has enough line in the housing to reach the deck, then follow the wire down into the back of the housing and cram it with about a fist full of the wax.
Note: There are other lights that aren't so easy, but this is the most common. The crew who installed your liner should be able to fix it.
Hope this helps.
If the water is visibly coming out the backwash/waste line, it is, in fact, either the spider gasket or top half or the multiport valve on the filter. Not all multiports have user replaceable gaskets.
If you have a flooded suction, it will drain on a continuous basis but slower when the pump is off.
If the pool is fully plugged and continues to leak and you have a light, the conduit is broken or rotted, or the niche has a hole in it. Sealing it with potting compound or butyl tape should solve it. I assume they used new gaskets when you changed the liner.
If the leak stopped when the pool was plugged, then a pressure test is called for.
It is possible there is more than one leak.
Scott
Hi Mari,
I was wondering if you ever found a solution to this issue? I am having a similar problem with my vinyl-lined pool where it is losing water still after I closed it. The water level is now below the skimmer and the jets and I'm stumped.
Any insight would be appreciated.
Thanks.
Got a light?
A main drain?
How old is the liner?
Scott
Hi Scott,
Thanks for the quick response.
-No light
-There is a main drain in the deep end
-I don't know the exact age of the liner - I would assume it's original to the pool, so it has to be at least 15-20 years old.
I did have a leaking spider gasket during the season, but I replaced that and sealed it up good and tight.
A call to American Leak Detect sounds to be in order. They can electronically sweep the liner and drain to find the leak.
Scott
