intellitouch: selecting pump speeds at panel?
Posted by Backyard_vacation (My Page) on
Sun, Aug 12, 12 at 16:57
How can i set up the extra AUX buttons on the Intellitouch panels (i9 and i10) to select Intellifo speeds when in service mode? I can use the panel in service mode to change valves and for anything connected to a relay. I can turn a speed on and off with the spa side remote, the IS4 remote and my iPhone. When i turn these speeds on and off, the lights at the assigned AUX button on the panel turn on and off but it is just an indicator light as the button on the panel does not turn the speed on and off. I have Screenlogic which is great for doing the setup, modification, and control from my iMac but that is inside my house and upstairs. When i am working on the pool, it would be very helpful to change speeds from the panel instead of using my iPhone with wet or dirty hands. Thank you
RE: intellitouch: selecting pump speeds at panel?
You can't. When the Intellitouch is in service mode, communications to the Intelliflow pump are disconnected.
Scott
Thank you Scott. I had a feeling that was the answer but i wanted to be sure. Coincidentally, right before i posted this question, I read the thread with the amazing and wonderful news of you now being in remission. I had not read any updates for a while and what a great surprise. I am so happy for you and your family. You are a very giving person who has helped so many for years. It's great when the expression "What goes around comes around" is about something good happening to a good person.
