Switching to salt water
Posted by fwals (My Page) on
Sat, Aug 27, 11 at 15:09
My pool is under 20,000 gals. I built it 30 yrs. ago so I know it's properly bonded. I have resurfaced it from plaster to fiberglass and my equipment is all fairly new. It's all Pentair with VS 3050 pump and cartridge filter. I heat with solar and have a gas heater for the attached spa. Everything is controlled with an Easy Touch panel. Equipment pad is about 40' from the pool. The only metal I can think of would be two pool lights.
My dog drinks from the pool so should I be concerned? I figure it can't be worse then what she has been drinking for the last 9 yrs.
Even with proper bonding, can I expect problems with my lights?
Will an IC 40 be the size to go with?
How much of a learning curve can I expect? I installed all my equipment and programed the Easy Touch so I'm hoping it should be fairly easy.
Thanks
Frank
RE: Switching to salt water
Should be fine. If you can handle a VCR, you can handle this.
Get a good test kit.
The IC40 will be fine.
The dog will be fine.
Scott
Thank you, thats what I was hoping to hear.
Frank
Once you learn the menu, the VCR will have been the harder task, btw.
Scott
