Wed, Aug 17, 11 at 14:28
| Recently got Stegmeier Desert Deck applied to wet concrete. PB says no need to seal after 30 days but mfgr. recommends this . . . second time getting this done due to prior problems. Suggestions on experienced members would be helpful and appreciated. |
| clockerfields, I've used Stegmeier products since about 1969. I've never sealed Kool Deck. The seal they recommend is for areas that have distinct freeze/thaw cycles. Their sealer is to protect against water penetrating the pours in the surface. I built pools in a climate that rarely had temps drop below freezing. I have seen frost damage to Kool Deck when the temps dip down to the teens. Hope this helps you a bit. Good luck. |
- Posted by clockerfields (My Page) on Thu, Aug 18, 11 at 14:56
| Thx. I live in NE N.J. and we get cold winters, certainly below freezing. |
