Tue, Aug 7, 12 at 12:33
| My pool is finished and during programming of the intellitouch it became apparent that the return line for the Polaris 280 is plumbed in with my other 4 returns. The return port for the Polaris is on the side of the pool with the 2 skimmers and opposite the other 4 returns. Since the Polaris return is always running opposite the other returns it would seem that the action of the polaris return is fighting the skimming current of my other 4 ports. Also, there is a loss of pressure driving the Polaris because water is flowing from the other 4 returns rather than exclusively from the Polaris return port.
My understanding is that the manufacturer recommends a dedicated return for the 280 with a pressure of 30. Whay should I do? I would like my pb to fix it and set things up thecright way. |
| buzz2, It appears that you need to ask the pb to make it right. All pressure cleaners need a dedicated line. A 1 1/2" line is standard and should be run from the equipment to the center of one of the long walls. Good luck. |
