Sun, Aug 29, 10 at 11:57
| The bolts on the return head rotted and I replaced them with new stainless steel bolts and nuts. (This occured becuase Raypak used the wrong size gasket to seal the header onto the tube bundle).
I still see a small amount of condensation on the tube bundle which leads me to think the bundle itself needs to be replaced. It will cost me $600-$800 to replace this part and I am hesitant to invest so much into this heater. Is it OK to continue to run the heater with this small amount of leaking? |
| Is it a leak or condensation? Warm and humid air gets cooled by the water running through the heater when it isn't fired up. If it's just condensation, it will dry up after a minute when the heater is fired up. A leak is a problem. Condensation is not. Scott |
