Controls, Heating, Etc
cnr1089
13 years ago
HOME TECHSwitch On the Phone-Controlled Home
Lock your front door from afar, let your thermostat set itself and more when you use your phone as a control device
Full StoryHEALTHY HOMEWhat to Know About Controlling Dust During Remodeling
You can't eliminate dust during construction, but there are ways to contain and remove as much of it as possible
Full StoryBATHROOM DESIGNHow to Place Shower Controls for Bathing Bliss
Body jets, handhelds and showerheads are only as good as their placement. Here's how to get it right
Full StoryHOUSEKEEPINGLower Your Heating Bills With Some Simple Weather Stripping
Plug the holes in your house this winter to make sure cold air stays where it belongs: outside
Full StoryGREAT HOME PROJECTSHow to Add a Radiant Heat System
Enjoy comfy, consistent temperatures and maybe even energy savings with hydronic heating and cooling
Full StoryFLOORSIs Radiant Heating or Cooling Right for You?
Questions to ask before you go for one of these temperature systems in your floors or walls (yes, walls)
Full StoryBATHROOM DESIGNWarm Up Your Bathroom With Heated Floors
If your bathroom floor is leaving you cold, try warming up to an electric heating system
Full StoryFLOORSWhat to Ask When Considering Heated Floors
These questions can help you decide if radiant floor heating is right for you — and what your options are
Full StoryFLOORSFloors Warm Up to Radiant Heat
Toasty toes and money saved are just two benefits of radiant heat under your concrete, wood or tile floors
Full StoryGREEN BUILDINGInsulation Basics: Heat, R-Value and the Building Envelope
Learn how heat moves through a home and the materials that can stop it, to make sure your insulation is as effective as you think
Full StoryColumbus Area's Luxury Design Build Firm | 17x Best of Houzz Winner!
More Discussions
just-a-pb
Grandview Swimming Pool Builders · Huntsville Swimming Pool Builders · Norfolk Landscape Architects & Landscape Designers · Lyons Landscape Architects & Landscape Designers · Manhattan Beach Landscape Architects & Landscape Designers · South Orange Landscape Architects & Landscape Designers · Alpharetta Landscape Contractors · Arden-Arcade Landscape Contractors · Choctaw Landscape Contractors · Davis Landscape Contractors · Ridgewood Landscape Contractors · Tewksbury Landscape Contractors · Wallingford Landscape Contractors · Wickliffe Landscape Contractors · Palmetto Decks, Patios & Outdoor Enclosures
