Grounding Question-Hurricane Irene
Posted by thejimbar (My Page) on
Sat, Aug 27, 11 at 8:35
Does anyone know if I can tap tap onto the bonding/grounding clips on my pool pumps to ground a gas powered generator? Hurricane Irene coming and may need to run generator for sump pump in basement.
RE: Grounding Question-Hurricane Irene
Bond is not ground.
Right outside the meter to your house should be your ground rod. If you need an extension, I suggest booster cables for jump starting a car.
Scott
Scott, u da man. Done, perfect!
